RV.Net Open Roads Forum: Truck Campers: DC wiring / Inverter install
 > DC wiring / Inverter install
2oldman
Winchester WA
Posted: 04/23/12 01:42pm Link  |  Print  |  Notify Moderator
DiscoChicken wrote:
2oldman wrote:
DiscoChicken wrote:
From the inverter to AC outlets. Should I be using something else?
Don't the AC outlets already have wire to the breaker box?
I'm running AC outlets from an inverter.
Understood. Question remains.
DiscoChicken
Lawrenceville, GA
Posted: 04/23/12 02:03pm Link  |  Print  |  Notify Moderator
Ok. I hope you find an answer.
Adventurer/Ford
Photomike
Southern Alberta or where the camper is parked!
Posted: 04/23/12 02:09pm Link  |  Print  |  Notify Moderator
2oldman wrote:
Nah,don't bother. What I'm wondering is.. why are you pulling 120v wire?
If I understand correctly -
You put the inverter close to the battery, then you run 120v wire from inverter to the location of the plugs.
2002 GMC 2500HD 4x4 4 Door
1992 Northern Lite 9'- 6" Camper
Homemade Cargo Trailer for hauling supplies
Advanced Elements Kayaks
Border Collie Guard Dog
enblethen
Moses Lake, WA
Posted: 04/23/12 02:10pm Link  |  Print  |  Notify Moderator
#6 wire seems small. What is the rating of the inverter you are installing?
Make and model of inverter will help.
If it is the 300 watt unit, it requires a 100 amp feed at 12 volts DC. This unit will not run much more then a computer,printer and maybe a couple cell phone chargers.
sine 300
Bud
USAF Retired
Suzuki XL7 pushing Pace Arrow
DiscoChicken
Lawrenceville, GA
Posted: 04/23/12 02:24pm Link  |  Print  |  Notify Moderator
sine 300
Morningstar SureSine 300. 6 is what the install manual calls for. I have the inline 100 amp fuse.
I've checked the usage of my devices already. 300w is all I need.
jr3316
Mount Shasta, CA
Posted: 04/23/12 05:17pm Link  |  Print  |  Notify Moderator
DiscoChicken,
Where are you going to install your outlet that will be connected directly from the inverter?
* This post was edited 04/23/12 05:32pm by jr3316 *
2008 Dodge Ram 3500 6.7L, Automatic, Quad-Cab 4x4 DRW Diesel
Torklift Tiedowns, Rancho 9000xl wireless, Firestone Airbags, Fastguns, Helwig Bigwig Sway Bar, Torklift Stable Loads, Morningstar 300W Inverter
2006 Arctic Fox 1140 Dry Bath
smkettner
Posted: 04/24/12 12:58pm Link  |  Print  |  Notify Moderator
I wired mine into the system because the inverter only had two outlets and I had about 5 things plugged in with a jumble of cords.
Now the TV, dvd, laptop, ipod, phone, drill can all run/charge in their own place out of the way.
675 watts solar
wnjj
Cornelius, Oregon
Posted: 04/23/12 10:58pm Link  |  Print  |  Notify Moderator
Allow me to translate:
Why are you running new wire to the outlets rather than wiring the inverter to the panel?
Answer: Because he probably wants to have independent outlets so as to not have to worry about backfeeding the rest of the panel with inverter power.
smkettner
Posted: 04/23/12 11:42pm Link  |  Print  |  Notify Moderator
I mounted my 300w inverter behind the power distribution panel.
12v connected to the main battery feed. That would be the #6 in your case.
I then connected the 120v power to the existing outlets with a transfer switch. I used two switches to power both convenience circuits.
http://www.bestconverter.com/Xantrex-Pro........Inline-15-Amp-Transfer-Switch_p_457.html
Touch the romote power button and instant power for the toys.
No pulling wire, no new outlets.
enblethen
Moses Lake, WA
Posted: 04/24/12 06:46am Link  |  Print  |  Notify Moderator
He is probably using one dedicated outlet to the small inverter. He cannot operate much load.
