mojoroo
Midwest
Title pretty well covers my questions. Wondering if the Barker 3500 24'' is needed over a 18''. Looks to be about 80-90$ more for the 24''
Also any big pluses over the Barker and Atwood?
Sandia Man
Rio Rancho, NM
Atwood and Barker both offer quality power jacks so there may not be much advantage one over the other. I have a Barker 3500 and the 18" stroke works fine for us, but we do use a tongue jack stand we purchased from CW that gives us an extra 6" or so. Good idea to get one of the higher capacity power jacks for the extra torque needed to raise the tow vehicle when installing/removing WD bars.
tdeal823
N.W. Ohio
If you go off the beaten path often the bigger travel will come in to play with camping on uneven land.
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion
02 F250 4x4 Auto Ex LWB SRW 7.3L B&W, RideRite, 5"exhaust. TW6 chip. 195k
2011 Sabre 32BHOK-6
mojoroo
Midwest
Is their an issue with clearance? Or do they retract the same height?
alfredmay
West Milford, NJ / Donna, TX
You do not need the extra height. All you need do is carry a block of wood that is 6 inches high. If you are in an area that has a lot of slope, then place the wood block under the jack pole before jacking.
Both jacks retract all the way........ no clearance problems with either length.
Alfred May
2005 Excursion V10 4.30 4x4
2002 Cedar Creek 30RBS TT by Forest River
Reese Dual Cam
Tekonsha Prodigy
knesdad
Wisconsin
One thing the Barker allows you to do is rotate the motor to give you more clearance when opening the tailgate. Comes in handy if you can't get the tailgate open all the way and it hits the motor.
I've always had a Barker with the 18" lift, but with the new trailer sitting higher and a higher truck I put on a Barker VIP 3500 with a 24" lift. The only thing you really notice is that the motor sits 6" higher. Plenty of tailgate clearance now and no need to rotate the motor.
PM me if you're interested in an unused Atwood still in the box...
Dave.
Dave & Sue
Kiley & Emily
Izzie (Beagle/Bichon/Mini Poodle)
2012 Ford F150 XLT EB SS CRW 6.5 Max Tow
2012 Dutchmen Kodiak 284BHSL -- Dutchmen Owners
mojoroo
Midwest
Thanx all. I ordered a Barker 3500 24 " from Amazon along with a pair of x checks, and landing gear drill adapter for $360 shipped.
