Luke Porter
Not on the road :(
Does WalMart make keys? Like for my RV's deadbolt? In what department?
Yep, actually drove to all of these places---in the last eight years. Missed Rhode Island and New Jersey.
Homer
Northeast Indiana
Yes they do. The Key machine is in different places at different Wal-Marts, but usually they are in the hardware or camping department. The big question will they have the blank you need for your key. There is one blank that is difficult to find anywhere but a lock smith. I have forgotten the name of it. Chances are good they can make what you want.
Jamboree89
Pennsylvania
They also make them at Lowes and Home Depot.
1998 Monaco Dynasty
Scion Xb
2 Labs
mlts22
Austin, Texas
You would be surprised on this: Lowe's has a cartridge based key cutting system that makes blanks a lot better than the locksmiths I've tried, assuming they have the blank.
For your RV's deadbolt, I'd not bother with either locksmiths or the hardware store. Get the key code off your RV's key (assuming it starts with HF and has three numbers), then go here and have your keys made the right way -- stamped with a code from the factory. Guaranteed to work unless the code was wrong.
The last time I had RV keys cut by a locksmith, the guy put the wrong key in the wrong clamp on the cutter, leaving me without originals (although I did have another set of keys so wasn't totally SOL.) So, if I can buy keys just by code, I do so.
Janss
Sedona, AZ
The key machine where I've had keys made is at the automotive desk at Walmart.
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
vic46
Red Deer, Alberta, Canada
From my experience with having keys cut at Wal Mart, Totem, Canadian Tire and Home Depot, save yourself some frustration and go to a look smith to get keys cut. One trip is always better than two or more. They may be slightly more but, the value is clearly there!
Vic
Lack of common sense is the greatest mental illness known to mankind.
BB_TX
McKinney, Texas
I agree that the problem will be finding a place with the blank. Not a common one. I had to go to a locksmith before I found a place with the correct blank. Hardware store, Home Depot, Lowe's, did not have it.
fpresto
Maryland
Most RV Dealer part departments have the blanks and can make the keys. I have never had any luck finding them anywhere else.
USN Retired
2007 Cedar Creek 30 RLSTS
2008 F350, DRW, V-10, B&W hitch,
Pressure Pro, JT Strongarms
skipnchar
Topeka or somewhere else
LOTS of places cut keys but they don't always have the proper blank. BEST practice is to find a lock smith as they generally have the largest selection of blanks.
Big Katuna
Deland, FL
The blanks you need are probably Trimark and Walmart won't have them. I vote for goig to a real locksmith.
My Kharma ran over my Dogma.
