RV.Net Open Roads Forum: Heater and Converter Housing
 > Heater and Converter Housing
higherroad
Atlanta
Posted: 04/23/12 03:03pm Link  |  Print  |  Notify Moderator
On my 1992 Roadtrek 210 the heater is mounted under the passenger side dinette seat. The converter is a Magnetek 6300B and is nearly opposite of the heater on the drivers side couch seat. When I make the dinette into a bed the heat blows nearly directly across the aisle and make the metal housing on the converter pretty hot. Is this a problem. The Roadtrek has been around a while so I guess it hasn't hurt it so far. But what are the thoughts on this? Thanks.
VE3ESN
Ontario, Canada
Posted: 04/24/12 06:20am Link  |  Print  |  Notify Moderator
Our 1996 190 Versatile has the same configuration, and we haven't noticed any problems. We did however replace the Magnetek converter as we found that this old single-stage technology was detrimental to the house battery life. The replacement is a Progressive Dynamics 45 A unit with the "charge wizard". You might be mistaken that the heat you feel on the metal housing of your Magnetek is coming from the furnace; it's more likely being generated within the converter itself.
Jerry & Susie
1996 Roadtrek 190 Versatile (Dodge 5.2 L)
FMCA F390585
Trees are being destroyed through the transportation of invasive insects and diseases in firewood. For more information, please visit www.dontmovefirewood.org
