RV.Net Open Roads Forum: Removal of small concrete splash on camper door?
 > Removal of small concrete splash on camper door?
Tonijim
MA
Posted: 04/23/12 03:23pm Link  |  Print  |  Notify Moderator
We somehow managed to pick up 4-5 small (dime-size or less)splashes (now hardened)of concrete on one of our exterior storage doors.
Any ideas on how to safely remove them without damaging the finish?
Thanks
Jim
troll3193
SouthWest, MI USA
Posted: 04/23/12 04:29pm Link  |  Print  |  Notify Moderator
i would try white vinegar and a soft cloth.
I had concrete on my truck a while back and it worked..
vinegar is a weak acid and should clean it up..
Bryan
2006 RAM 3500 MegaCab w/Cummins Turbo Diesel
Mopar Exhaust Brake
2004 Dutchemen 31BK
Jagtech
Sunny Southern Alberta, Canada
Posted: 04/23/12 05:06pm Link  |  Print  |  Notify Moderator
Pressure washer, start with low - medium pressure.
1998 Triple E F53 with 460 Ford
1995 Jeep Wrangler toad
BobJoh
Whitestown, IN 46075
Posted: 04/23/12 07:33pm Link  |  Print  |  Notify Moderator
I bought 'Muratic Acid' at Menards home supply in the area for kitchen tile... KEEP safe away from children.. it is weak 10% H2SO4
Used to clean up rock wall and splashes on sink counter tops..
BobJoh
Raymon
Phoenixville, PA
Posted: 04/23/12 05:28pm Link  |  Print  |  Notify Moderator
This would be my suggestion also. Start with very low pressure and try to spray at an angle either from the right or left side. Do NOT spray straight on. Increase the pressure very slowly until you have just enough pressure to remove the concrete. Once the spots are removed, if there are any minor markings (scratches), try to remove the markings with a good automotive paste wax. Hope this works.
Ray
weasel4
Alberta
Posted: 04/23/12 06:09pm Link  |  Print  |  Notify Moderator
Having had a concrete pumper blow a hose at my house several years ago, I would not use a pressure washer. They tried that on my vehicles and roof, needless to say the roof needed all new shingles as the pressure blew off the coating of my shingles.
To remove the dried concrete off my two affected vehicles, they use a Qtip soaked in muriatic acid and dabbed the concrete until it softened and then used copious amounts of water to rinse the area. Didn't affected the paint on the vehicle a bit and removed the concrete.
BTC
Tonijim
MA
Posted: 04/24/12 08:29am Link  |  Print  |  Notify Moderator
Thanks to all!
Jim
larry barnhart
wenatchee. wa usa
Posted: 04/24/12 09:22am Link  |  Print  |  Notify Moderator
I can tell vinegar will eat concrete but hard to apply on a wall.
chevman
chevman
2001 35 ft avalon alpenlite RK
prodigy
easyrider/reese airhitch
trailair center point suspension
JT Strong Arm Stabilizers
KSH 55 inbed fuel tank
Garmin 2720
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
Tonijim
MA
Posted: 05/04/12 02:15pm Link  |  Print  |  Notify Moderator
Update on concrete splash removal. WHITE VINEGAR WORKS!
To those of you who suggested white vinegar - thanks. A Q tip applying small amounts of vinegar followed by a gentle scrape with the edge of a paint stirrer seems to have done the trick without visible damage to the finish.
Thanks to all!
Jim
