Wingnusa
Scott and Brenda Retired and Wingn the USA
donn0128 wrote: Do you want to end this? Install 17.5 inch tire and wheel package. I see it is finally an option on new pnes. And with a 4700 pound load rating you wont have problems again. What is your aggrivation worth?
X2! We changed a year ago and haven't had an issue since. No more driving in the rearview mirror!!
http://www.trailertiresandwheels.com/site/1284278/product/0377865
I also hope you kept the tire because GY paid for all my repairs 3 times. We have GY 114 "H" now...
Scott and Brenda Schnelle
Jasmine the Schnauzer/Sierra the CKCS
2006 KZ Escalade 36CKB
2007 Chevy C5500
FT Class of '06
Lifetime Good Sam's members
Lifetime NRA member
Sporting Clays Competitor, NSCA #621387
Level 1 Sporting Clays Instructor
NRA RSO
My Site
sdianel
Tampa, FL
Pat at Pro Tires in Denton TX recommended B F Goodrich ST230's for our Class A to replace Toyos. We are very pleased with the choice. B F Goodrich is owned by Michelin. The tires were made in America. He worked on Prevost and Country Coach RV's to name a few. Came to our site and changed the tires, aligned and balanced, checked the ride height. Great service, fair price.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
kakampers
Fulltimer
Wingnusa wrote: donn0128 wrote: Do you want to end this? Install 17.5 inch tire and wheel package. I see it is finally an option on new pnes. And with a 4700 pound load rating you wont have problems again. What is your aggrivation worth?
This is exactly what we just did too! Stuck with Goodyear 114's because GY is good about paying claims...but don't think we'll have to worry about that anymore. Oh,and by the way, the GY 114's have a capacity of 4,805 lbs per tire, not 4,700....
2013 Heartland Landmark Key Largo with Mor Ryde IS and disc brakes
2011 Chevy Silverado 3500 DRW Crew Cab Duramax Diesel
krmcg
New Boston, Texas
Well, we were coming home from a trip this past week and stopped for a rest. I looked at our tires and one Goodyear "g" tire was missing all the tread, just sidewalls and the steel belts left. Still had air pressure. Day was early and road cool and yes, I keep my rig weighed (I weigh every trip, annal I know but I like to know my weight as we full time in the rig). I am well under GY weight limit for maximum inflation, so I use their tire chart for inflation. I run 105# cold and have tire pressure monitors. After being on the road, the tire pressure goes up to 110 - 112 pounds. I had planned on replacing 2 of the tires after this trip, but now I had to get one new tire so I went ahead and bought the second one. Last year and the year before I had replaced the other 2 tires. One due to blowout, the other due to road hazard. I was in Hattiesburg,MS. on this trip and no tire was to be found. So I went to Jackson,MS. and was able to get 2 tires. My tire manufacture date was 2005, so I knew I needed to replace and that is why I was going to after this year. I called Goodyear and they did pro-rate the one bad tire but was hesitant since there is supposedly only a 4 year warranty and these tires were now 7 years old. In the future, my tires will get replaced at 4 years, period. As a side note, I previously ran 110# before the first blowout so I don't think my problems where inflation related.
Texas Two Steppers
Beaumont, TX
I didn't know anyone else made load range g tires. I just replaced 2 in Demming, NM coming home (Texas) from Death Valley, CA a couple of weeks ago. They were 3 yrs old. The other 2 I had to replace in May because of a broken spring. Mine were wearing on the edges. I keep from 105 to 110 psi in them and they heat up to 130ish when traveling. In Demming I took the rig over to a frame shop to have the axle checked. The guy there said that he had seen a lot of g Goodyear tires and that mine were experiencing what he considered the normal wear pattern for the tire and that they should be replaced every 3 years. He suggested going to 17.5 inch tires.
My first set lasted about 3 yrs. I may change over in a couple of years. I don't want to change now because I've got basically a new set at about $400. a pop.
2013 Duramax 3500 dually 4x4
2013 Excel Winslow 31RSE
TST tire monitor
Magnum MS 2012 inverter/charger
3-135w solar panels
Tristar controller
Trimetric monitor
4-6v Trojan t105 batteries
B & W companion 3000 hitch
Rossey
Appomattox, Virginia. / Rockville, Maryland
X3
Exactly what I did to solve problem !! Ordered from these folks (trailer tires & wheels . com) Goodyear 17 1/2 H rated 114's (Commercial) mounted on 17 1/2 wheels.... perfect fit (" plug & play") & no more blowout worries. They will ship wheels & tires pre mounted as a package on a pallet nicely shrink wrapped. If drop shipped to a local business in your area, you can save $$ on shipping.
Sooner Schooner
On a Roll
You may want to look at the Firestone Transforce, I use them on the truck and the 5th wheel.
richfaa
Ohio
G614 tires are blowing up?? I thought they were the cure all for cheap Chinese tires.Just purchased a new rig and paid extra for the G614 tires.
I would also be interested in the weight of the MS and the individual tire loads
We have our Montana weighed every Sept at our Fall rally by RVSEF and the first time we were weighed it was a eye opener.RVSEF documenttion indicates that @ 60% of Rv's weighed are over weight nationwide.We are long timers and run heavy. We have a hard time keeping below GVWR (RV) and GCWR.We have the pressure pro TMPS and keep a close eye on it. We also run 62/65MPH.
We are not happy to hear of G614 failures but the failures were on a much heavier unit..Could that be a factor???
2013 Montana 3402 Big Sky. 08 Ford F-350 6.4L
Snow_King
Gold Canyon, AZ
richfaa wrote: G614 tires are blowing up?? I thought they were the cure all for cheap Chinese tires.Just purchased a new rig and paid extra for the G614 tires.
Why don't you ask Goodyear Customer Service about this? It does seem like the G614 is not fool proof. Maybe 3750 pounds is pushing the limits of a 16" tire?
Somewhere in a Fifth Wheel - Where it does not Snow
joebedford
Jasper, Ontario
richfaa wrote: G614 tires are blowing up?? I thought they were the cure all for cheap Chinese tires.Just purchased a new rig and paid extra for the G614 tires. G614s were the cure for all my blowout worries on my previous trailer. I'm going to put them on my current rig when the Chinese tires wear out.
2011 Silverado 3500HD LTZ CCLB 6 x Michelin LTX MS2 80 psi
2011 Voltage 3950 6 x Bridgestone Duravis R250 80 psi
2004 H-D VRSCB(mine)
1996 / 2007 H-D / DFT FLHTCUI Trike(hers)
2004 Thor Dutchman 35SRV traded
2004 Dodge Ram 3500 5.9 CTD traded
