nadkaw1957
Reno
Just got back from our first trip of the spring... with the new Dometic 310 toilet I installed over the winter. I gotta say, it's one of the best mods I've done (and I've done quite a few). The porcelain bowl stayed clean and the foot flush was so much nicer than the hand flush... I recommend it, even if your old toilet is still working.
2011 Trail Sport 25S
2011 Ram 1500 5.7L Hemi
Lynnmor
Red Lion
I replaced my hand flush with a 310. I like it but it does seem to use much more water. One worry is that there is no overflow so if the valve develops a leak there may be a flood.
mph_medic
Southaven, MS (Outside Memphis, TN)
X2 here.. I bought mine off Ebay for $75 and was one of the best mods here too ... I don't feel like I'm sitting in a kids seat... It my new THRONE ...
Never do anything you wouldn't want to explain to the Paramedics...
1993 Damon Frontier Flyer
stormbytes
Wherever I may roam
The Dometic 310 was on my top-5 list of upgrades when I got my '94 class-A Winnebago. I whole-heartedly agree, well worth the money!
Mine was $149 shipped (ebay) bought fromt his seller -
http://www.ebay.com/itm/Sealand-310-China-toilet-White-Color-/220874665106?pt=Boat_Parts_Accessories_Gear&hash=item336d27ec92#ht_2572wt_922
She has it listed for $179 now (free shipping) but I think if you asked you might be able to get the same deal since I bought mine very recently.
The only p.i.t.a is the horizontal water inlet (my previous toilet was a Thetford IV with vertical, left side inlet) which is proving to be a major pain to adapt! I wish they had flex hose of some sort, much like a home toilet has, that could fit between the PEX 1/2 threads and toilet inlet.
austinjenna
Columbus, Ohio
Mine came standard and in fact I am waiting for the replacement unit to arrive at the dealers. Mine leaks between the base and the bowl and is also loose at that point (hence the leak). I figured it just needed to be tightened up so I took a look and see nothing to tighten. I get the manual out and see its sealed at the factory and nothing you can do about it. Stupid design. Oh well its under warranty
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
nadkaw1957
Reno
stormbytes wrote: The only p.i.t.a is the horizontal water inlet (my previous toilet was a Thetford IV with vertical, left side inlet) which is proving to be a major pain to adapt! I wish they had flex hose of some sort, much like a home toilet has, that could fit between the PEX 1/2 threads and toilet inlet.
I went to Home Depot, bought a SharkBite elbow with pex on one end and 1/2" male thread on the other. I also bought a 20" stainless steel hose with 1/2" female on both ends (right across the aisle). I cut off the existing pex line, and connected the elbow to it. I connected one end of the hose to the SharkBite elbow, made a loop with the hose and connected the other end to the toilet. It made the connection easy.
stormbytes
Wherever I may roam
nadkaw1957 wrote: I also bought a 20" stainless steel hose with 1/2" female on both ends (right across the aisle). I cut off the existing pex line, and connected the elbow to it. I connected one end of the hose to the SharkBite elbow, made a loop with the hose and connected the other end to the toilet.
I did exactly the same thing -- sans the Sharkbite fitting. I followed the existing 1/2" hose back to a T and removed that whole piece. When I tried to screw in my steal braided (I'm guessing that's what you meant as well) 1/2" FxF hose I couldn't get it on either end. On the pex side the T's threaded male has a tapered 'lip' and a similar issue on the toilet side of things.
Maybe I'm overcomplicating things. I'm reluctant to cut/modify the threaded nib on the toilet. I'm back to home depot later today and going the pex/crimp route. I've got a Flair-it female 1/2 threaded that will fit the toilet.
nadkaw1957
Reno
stormbytes wrote: On the pex side the T's threaded male has a tapered 'lip' and a similar issue on the toilet side of things.
The male fitting on the toilet does taper a tiny bit, but I had no trouble getting the stainless steel female to go and and tighten nicely; no leaks whatsoever. I used the Sharbite because I wanted to keep the shutoff valve that was installed inline in the pex. My T's are all crimped, so I couldn't just attach the stainless steel line to a T.
stormbytes
Wherever I may roam
nadkaw1957,
On the toilet (threaded 1/2" male) there's a lip sticking out beyond the threads that measures at least 1/4" in length. If we're talking about the same steel, braided/flexible hose as meant for household fixtures, The 1/2" threaded female is shallow and has a black bushing in there. The lip that sticks out from the toilet's threaded male butts up agains the bushing and shy of cutting it (the lip that is) I don't see how you managed to get that on without modifying anything.
I'm actually addressing this exact problem this morning and trying to work out a game plan.
nadkaw1957
Reno
stormbytes wrote: nadkaw1957,
Hmmmm - mine didn't have a lip on it... different production day, I guess. Is there a way you can remove that fitting and put a 1/2" nipple in it? Good luck.. let us know what you came up with.
