RV.Net Open Roads Forum: Dinghy Towing: JEEPS
Search only in Dinghy Towing
 > JEEPS
mojo41
parsonsburg,md
Posted: 04/23/12 05:48pm Link  |  Print  |  Notify Moderator
Would like an answer as to what is the newest Grand Cherokee or Limited that can be towed 4 down.I know the ones with the transfer cases will work by putting the tranfer case in neutral and the tranny in park.Will any of the others work without adding any dis-connects,etc.
Thanks,
Larry
rk911
Wheaton IL
Posted: 04/23/12 05:52pm Link  |  Print  |  Notify Moderator
Thanks,
Larry
depends. some can be modified, some can't and have to be trailered. best bet is to check the owner's manuals (available free online) or check with REMCO
73,
rich, n9dko
www.bananaboatbytes.com
I know a guy who's addicted to brake fulid. He says he can stop anytime.
2000 Itasca Suncruiser 35U
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
sch911
Rochester Hills, MI
No! it must be a 4 x 4 with a two speed TC. This means the upgraded TC. These have an electric Neutral switch included.
Chrysler/Dodge/Ram/Jeep Engineer
2003 Damon Challenger 348 Class A - F53 Triton V10
kedanie
Albuquerque, NM
Posted: 04/23/12 06:51pm Link  |  Print  |  Notify Moderator
We tow our 2012 Grand Cherokee Overland 4 down with no problem. There is no steering wheel lock, so no key needs to be left in ignition. With engine off and key on, put transmission in neutral, then push the transfer case neutral button. The transfer case shifts to neutral an then start the engine, shift to reverse to check that T-case is in neutral. Turn off engine and place transmission in park and remove the key. Release the parking brake and head down the road.
It really is easy.
Keith
Keith, Gloria & Charlie(Spoiled Rotten Boston Terrier)
2010 Damon Astoria 3470
2012 Jeep Grand Cherokee Overland
USAF 1968-1976 Viet Nam Veteran
ssocal
Highland SoCal
Posted: 04/23/12 07:41pm Link  |  Print  |  Notify Moderator
Thanks,
Larry
According to our owners manual, only the onex with the transfer case (Quadra trak II / Quadra drive II) can be towed 4 down.
2011 Fleetwood Expedition 38B
2011 Grand Cherokee
2006 2500 Duramax 4x4
31' Rockwood
imgoin4it
Alamogordo, NM USA
Posted: 04/23/12 07:45pm Link  |  Print  |  Notify Moderator
There are two models of the new Grand Cherokee. One has a drive trane that can be towed 4 down and the other does not. Just had this same discussion with several jeep salesmen. After getting the books out they all learned the difference. I have forgotten the mode;, but the one you can tow has a round knob switch on the dash you switch to neutral, then put the transmission to "park" and you are ready to go.
Retired and loving it
Living in the Land of Enchantment
Traveling in 2007 Newmar KSDP
towing a Jeep Liberty
with a Blue Ox tow bar
rk911
Wheaton IL
Posted: 04/23/12 08:17pm Link  |  Print  |  Notify Moderator
basic rule of thumb...the jeep can be flat towed if the jeep has a neutral position on the txfr case and the driver can shift the txfr case into that neutral position. all jeeps that can be flat towed can be flat towed without any time, mileage or speed restrictions.
RayChez
Barstow, Ca. USA
Posted: 04/23/12 08:23pm Link  |  Print  |  Notify Moderator
I was checking the grand cherokee about a month ago, and I was surprised that some can be towed and some can not be towed. So when checking them out you have to ask and make sure before you buy one that might not be towable.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
JohnnyT
Goshen New York
Posted: 04/24/12 04:04am Link  |  Print  |  Notify Moderator
Moved from class A forum
rk911
Wheaton IL
Posted: 04/24/12 08:54am Link  |  Print  |  Notify Moderator
do not take the sales critter's word for it...demand to see the owner's manual for the specific vehicle. many sales people have no clue one way or the other, many more assume any vehicle can be towed and a few will say anything to make a sale.
 > JEEPS
