Alfred622
Rochester, MN
I noticed a "spill" under our Class A about where the driver rear tires are. I thought it might be hydraulic fluid leaking from a Kwikee level jack near the wheel. However, I went to work on it a few days later and the "spill" looks like it evaporated. If I had a leaking hydraulic line, would that have evaporated in a few days?
I also noticed there was a lot of condensation on the gas tank of our MH. If there was a huge amount of condensation, that might have made the puddle. I'd guess the puddle was maybe 3' x 2' in size.
The fluid seemed clear also. Likely water?
Alfred
2005 Sightseer with Workhorse, ReadyBrute Elite towing 2003 Honda CRV
Map below shows states where we actually camped.....
romore
Canada
Hydraulic oil has a rather distinctive smell and will leave a stain. Run your finger across and take a sniff. If not water you will be able to tell the difference.
Mustang7370
Washington State
Dexron III or any other trans/hyd fluid will not evaporate
Chris and Kelli Withers
Ferndale, WA.
haddy1
Chesterfield, MO
A full tank of cold soaked fuel added to a warm moist spring day equals A LOT of condensation.
2012 Tiffin Phaeton 36QSH
2007 Jeep Wrangler Toad
ArchHoagland
Clovis, CA, USA
Last week I spilled about three quarts of used Dexron III on my concrete pad where I keep my motorhome after changing the transmission fluid.
I'm here to tell you that stuff doesn't vanish by itself!
Had to use a degreaser twice over a couple days to clean it up.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
Nothing is either good or bad, but thinking makes it so.
PackerBacker
Montreal (Qc) Adirondacks (NY) Myrtle Beach (SC)
I've found liquid on the ground next to an inside dual tire that had me guessing. It turned out to be the neighbor's cat; needless to say what the liquid was!
Eric
2009 Holiday Rambler Admiral 33SFS (34' 3")
2008 Jeep Liberty - North Edition (4x4 auto)
FQCC/Camping Quebec, KOA, Good Sam, Coach-Net
Alfred622
Rochester, MN
Thanks All! Enjoyed the story about the Cat! I think haddy1 figured it out. I checked my fuel tank on a warm moist day after a cold night. You're right, that can generate a lot of condensation!
