RV.Net Open Roads Forum: ODB 2 scanner
Golden_HVAC
Fulltime, CA, USA
Posted: 04/24/12 12:07am Link  |  Print  |  Notify Moderator
Hi,
Does anyone have a ODB2 scanner that they really like?
I saw this one on sale at Harbor freight, and wondered if it is any good, if anyone is using this brand tool?
OBD2 scanner
It says it will work with any car 1996 and newer, and can be refreshed by plugging into a USB port and download software updates.
If someone has one, can you get engine temperature? What about transmission temperature from the gauge? That might be handy.
Fred.
ronfisherman
SE Michigan
Posted: 04/24/12 03:32am Link  |  Print  |  Notify Moderator
For a little more you can get a ScanGaugeII. It will give a lot of data including trans temperature for most vehicles.
You would have to lockup the description of the code on internet. The HF model appears to give that info.
Kodiak Chassis Class C Forum
dodge guy
Bartlett IL
Posted: 04/24/12 05:37am Link  |  Print  |  Notify Moderator
I have a Craftsman one that also reads abs and air bag codes. it was $150 with free shipping I also had a 40% off coupon. these are all mostly made by one manuf. and given different color cases and names, craftsman, actron, OTC, Matco etc. etc.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
nremtp143
Georgia
Posted: 04/24/12 05:43am Link  |  Print  |  Notify Moderator
In addition to my Edge CTS, I have an Innova 3140 that I like very well. The price on these has really come down quite a bit recently.
2012 Sandpiper 365SAQ, Goodyear G614s, TST TPMS
2010 F350 DRW 6.4L 4x4, Edge CTS, B&W Companion, Viair 10007 air system, Firestone Ride-Rites,Flo-Pro cold air pipe
2001 Excursion Limited 7.3L 4x4, V/B Springs
2001 Silverado 3500 DRW CCLB 8.1L/Allison 4x4
travelzoo
NW
Posted: 04/24/12 06:34am Link  |  Print  |  Notify Moderator
From another forum I read the Scangauge II can be purchased HERE for $134.95. Just join the forum, then scroll down the page to find the offer for $134.95.
n7bsn
Yes
Posted: 04/24/12 07:58am Link  |  Print  |  Notify Moderator
I have that model, I actually got it for a bit less (better sale plus 20% off coupon)
I'd buy it again
It does not support the VW/Audi propriety add-on codes, nor will it reset anyones "oil change" code. But it works for what it says it will do.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
overdrive75
Whitmore Lake, MI
Posted: 04/24/12 08:48am Link  |  Print  |  Notify Moderator
This is thie system I like. I do not work for them but have used there products. DashDaq can give you alot of information, more than you might want.
2002 Chevy 2500HD 4x4 6.0L 4L85E 4.10 Full Floater 9200GVW 16K GCVW
2009 Rockwood Roo 23SS for camping
1989 Searay 230CC for the weekends when not camping.
Normk
Canada's Wet Coast
Posted: 04/24/12 09:30am Link  |  Print  |  Notify Moderator
Depends what you want to do with the unit and how much you will use. I have one which connects to a laptop by USB and displays onto the laptop screen. It is not as compact as the hand held units but a lot less costly and easier to read the data. I have had mixed results with the Bluetooth models having set some up for friends and failing in several cases.
The limitation on the data which will be displayed lies largely with the vehicle's data output as the scanner can only display what the vehicle outputs to the OBD2 port.
FWIW, not all post 1996 vehicles will connect to OBD2 scanners as some got by the cut-off. If memory serves a few Ford Windstars....can't recall the few others...
Diesels are a spotty coverage so one may wish to check before buying. Some won't display while others display only limited information. Most of the lower cost (all which I have seen) will not display body computer information which may or may not be of interest.
HIH
Norm
Dave-Sparky
Woodinville, Washington
Posted: 04/24/12 09:54am Link  |  Print  |  Notify Moderator
While looking for something that would let me watch the engine/transmission temp I came across an ad for the Garmin Ecoroute HD unit.
This plugs into your OBD2 port and uses blue tooth to connect to your Garmin (mine is the 1390LMT)
Works well and has several screens that can be displayed. The largest one will display as guages up to 5 of 20 readings. The ones I am using are RPM, Voltage, engine load, engine temp and vacuum.
I have found that while using these while towing I have upped my mileage about 2 mpg by not overloading or lugging the engine.
Lots of options out there.
Dave
Dave and Colleen
Colleen's Beach House
1991 Dutchman TT 24FK
2002 GMC Safari AWD
ecoast
NW NJ's Highlands
Posted: 04/24/12 10:11am Link  |  Print  |  Notify Moderator
you can also get a bluetooth obd2 adapter for about $25/35 shipped and be able to use it with your laptop or smart phone, and unlike a scangauge, it will not be limited to use in only one vehicle...
07 5.9 CTD & 2000 Northstar Laredo TC towing 87 Samurai ORV on dual axle trailer
