mph_medic
Southaven, MS (Outside Memphis, TN)
Ok I know I'm cheap but for I refuse to pay $130+ for a Gen-turi Generator Exhaust System. I made mine from 3" dryer vent pipe and then found a top cap and drilled the spot weld out to use it at the open space from the elbow to the pipe.. Will prime and paint it later..all was baught at Lowes for a total of $18.94 ...
Never do anything you wouldn't want to explain to the Paramedics...
1993 Damon Frontier Flyer
rv2go
Fulltime (Knoxville, TN).... or someplace else
Looks Good. Could you post a close up picture of how you connected the top cap to the elbow to get the gap?
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
www.rv2go.us
I'm here #4335
Travel Photos
Dieselgem
Northeast
Nice job... But I would be very careful in use, I had a Gen-turi and the plastic pipe does not get as hot. I would think you need to exercise caution after you use it. It is possible for the metal pipe to really heat up.
08-KZ Escalade 41'CKS Escalade
2008 F450 Super Duty Truck
2003 FLSTS
2003 FLSTC (Wife's)
mph_medic
Here is the cap that I used for the open space.. I turned it upside down and drilled out the spot weld and then used the tabs as the brace to connect to the elbow.. My elbow was a 1" electric bend and I used a 1" screw clamp connector..Since I had all ready drilled the tabs I just marked the holes on the elbow and pop rivet it together..
Elbow -->
Clamp -->
Cap -->
Mod Cap -->
W4MBG
Williamsburg, VA
very nice! i used a white metal downspout. the bent pipe will get very hot. the chimney will get hot too, about 150 degrees.
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
mph_medic
After I put it up I ran the generator for a hour while I worked on the other mods and I checked the heat and the blbow was Hot but the pipe going up was only warm and I even tried the tissue test and it worked.. now all the kids want to do is see tissue fly out the top of the pipe LOL....
jauguston
Bellingham, WA
There are lots of DIY ways of doing it. The only thing to be sure of no matter how you build it is the tube does not get hot enough to burn some unsuspecting child that might touch it. Shoot the tube with a infared heat gun after the generator has worked hard for a little while not just run with no load.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
SCVJeff
Santa Clarita, CA.
Just curious why the top hat? The whole point is to exhaust as high as possible. I'd think the top hat would create exhaust turbulence on the roof and allow it to settle and spill back over the sides?
Jeff - WA6EQU
mph_medic
i did not put the top hat on the top I used it after took the top off and used the tabs and ring to attached it to the elbow..
Kiwi_too
Western, WA
This one actually looks nice. Good job.
May God bless your travels
Me, The Wonderful Wife
and two Spastic Border Collies
U.S. Army Retired
2004 Coachmen Aurora, 3480DS
2007 Saturn Outlook, FROG
