RV.Net Open Roads Forum: Home made Gen-turi for $20.00
 > Home made Gen-turi for $20.00
tenbear
Northern Vermont, USA
Posted: 04/24/12 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Looks really good. How did you attach the pipe to the RV wall, or roof?
Class C, 2004/5 Four Winds Dutchman Express 28A, Chevy chassis
2010 Subaru Impreza Sedan
Camped in 45 states, 7 Provinces and 1 Territory
mph_medic
Southaven, MS (Outside Memphis, TN)
Posted: 04/24/12 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
two suction cups and a bungy cord screwed into the pipe that was I would not lose it LOL
Never do anything you wouldn't want to explain to the Paramedics...
1993 Damon Frontier Flyer
Photog101
Garden City, Michigan
Posted: 04/24/12 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have a question about these extended exhausts. Being that CO usually pools in lower places, like basements (the reason that I have a Co detector in my basement), what is the effect of the discharged gas if you have the roof vents open?
I would worry about the gases coming in, especially if there was no breeze and the you were in colder temps.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
sc3283
St Louis
Posted: 04/24/12 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
FAR FAR less chance of CO poisoning running the exhaust up than there is letting it pool underneath a vehicle. More than 1 has not awakened the next morning with no exhaust standpipe due to CO fumes building underneath and seeping inside the RV
04 D-Max Crew Dually
96 Monaco Dynasty 36'
Ron3rd
Upland, CA USA
Posted: 04/25/12 05:48am Link  |  Quote  |  Print  |  Notify Moderator
This might be a dumb question, but could the long pipe that runs up the side of the RV be made of thick PVC or ABS? Or would the exhaust be hot enough to melt the plastic?
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
jauguston
Bellingham, WA
Posted: 04/25/12 07:57am Link  |  Quote  |  Print  |  Notify Moderator
Ron,
The Genturi IS plastic pipe. Mine gets to about 100 degrees when my Onan QD 7500 diesel generator is working to run both of my rooftop AC units. Never what could be called HOT.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
W4MBG
Williamsburg, VA
Posted: 04/25/12 08:32am Link  |  Quote  |  Print  |  Notify Moderator
do NOT use a plastic downspout. works fine with the genny running without a load, but will melt when you load it up. personal experience talking here...
1999 Winnebago Minnie, 29', Triton V10, mostly stock. So far...
jauguston
Bellingham, WA
Posted: 04/25/12 08:49am Link  |  Quote  |  Print  |  Notify Moderator
The key to keeping the plastic pipe cool is the way the air gap is designed where the elbow blows the exhaust into the pipe. If you are going to build your own take a close look at a Genturi and specifically the way the exhaust elbow is placed in relation to the plastic pipe.
Jim
down home
south
Posted: 04/26/12 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
Note to RV Designers. Run the generator exhaust through the roof near or into the diesel exhaust also through the roof.
Everybody gets quiet and no diesel exhaust no much sound drifting around near the ground and into neighbors coach and around the campfire.
msiminoff
Silicon Valley, CA
Posted: 04/30/12 12:41am Link  |  Quote  |  Print  |  Notify Moderator
Nice work mph_medic, that looks like a clean setup!
The density of carbon monoxide (MW=28) is nearly identical to that of air (29) (i.e. it doesn't "pool in lower places"). However, CO is a product of combustion, and hot (exhaust) gasses rise due to convection. As a result of this convection, having the generator exhaust exit above the roofline is far safer than any location below the living space.
CO detectors should be installed in the locations where people breathe the air, and at (approximately) the height that their mouths & noses will be located... If you sleep or spend time in your basement (RV or home), then it makes sense to have a CO detector there, but that should be in addition to the one(s) in the living space(s).
Cheers,
-Mark
'04 Alpenlite Saratoga 935, 326W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins, Goerend Trans, Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Thuren trackbar, RS9000XL/MyRide
