box710
albany ny
I plan on leaving my 2008 bighorn on site in central Florida. I was wondering if I leave the unit plugged in if it will over charge my 2 agm batteries. This is my first fiver and am not really familiar with the process. Also if I leave it unplugged and disconnect the batteries will they go bad over the 6 months.Of the 2 options what do you think is the best on or is there a better option. Thanks in advance.
pianotuna
Regina, SK, Canada
Hi,
AGM batteries have extremely low self discharge rates. I would disconnect them and leave them.
Alternately you could add a modest solar system.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
garym114
Bluff Dale, Texas
I think disconnecting them is best. I would worry less if there was no power to the RV while in storage.
Charge them fully and disconnect the ground cable from the batteries to remove all load.
korbe
Northern California
I disconnect my 2 T105's at the end of my campin season after they get fully charged. I anticipated giving them a 24-hour charge about once a month, but didn't need to. After six months in my driveway, they didn't need much of a charge at all, and no water either.
2004 F250 SD PSD
2004 Crossroads Cruiser CF25RS
travelzoo
NW
You could plug into a timer and then allow the timer to only come on about a hour a day.
bpounds
Whittier CA
I wouldn't leave it plugged in if it will be 6 months completely unsupervised. Install a battery disconnect, and leave the shore cord unplugged.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Snow_King
Gold Canyon, AZ
Here is some info about AGM batteries. If you are going to leave it plugged in then you should verify the float voltage of your converter/charger.
http://www.firststartbatteries.com.au/faq.html
Somewhere in a Fifth Wheel - Where it does not Snow
Veebyes
Bermuda & Maryland
I have a single 4D AGM. It has been sitting disconnected & unattended since last November. I go back to it next Tuesday. In less than an hour I expect that it will be fully recovered from its winters sleep.
AGMs have a very very slow self discharge rate.
Leaving them on a trickle charge is not necessary & runs the risk of charger failure & cooking the batterys. An expensive loss. Seen it happen.
2007 Alpenlite 34RLR
