RV.Net Open Roads Forum: Class A Motorhomes: Windshield Cleaners
 > Windshield Cleaners
weathershak
Not sure, I need to look out the window
Posted: 04/25/12 09:43am Link  |  Print  |  Notify Moderator
Lobstah wrote:
I use Rain-X windshield washer...that way I don't have to remember to re-apply the Rain-X, which would usually become evident during the first rainstorm.
It provides a nice coating, and bugs come off very easily.
I don't use anything else.
Jim
We started using this stuff this past winter. It is a much better improvement than the so called blue stuff, which would leave blue stains across the front.
Full timing it since July 2012 My pics
crudeman
Posted: 04/25/12 10:37am Link  |  Print  |  Notify Moderator
jbretired wrote:
Over the years we have tried many types of washers for our windshield.
Bugs are the hardest to get cleaned.
What is the best cleaner solution to get a windshield cleaned
Windex and a small nail brush ( for the tuff bugs) does the trick.
Steve & Pat
Maggie- Hannah
2006 HR Ambassador PDQ
2010 Silverado
Weathertodd221
FL
Posted: 04/25/12 01:37pm Link  |  Print  |  Notify Moderator
rainx, steel wool, squeege, and soft clean cloth
dennyR
Holland, Michigan
Posted: 04/25/12 07:46pm Link  |  Print  |  Notify Moderator
Hot soapy water works really good! Used dryer sheet on the tough ones. As a plus, the price is something I can handle without pain.
2000 Newmar Dutchstar DP
2004 Road King
1994 Jeep Wrangler
royST
ann arbor
Posted: 04/25/12 08:24pm Link  |  Print  |  Notify Moderator
I use Aquapel Glass Windshield Cleaner and then coat the windshield with Rain X. Helps keep the windshield protected from all the gunk and bugs from really clinging and sticking on the windshield so it's easier to clean.
sowego
northwestern corner of the Nebraska panhandle
Posted: 04/26/12 06:44am Link  |  Print  |  Notify Moderator
There is a windshield washer fluid sold, I believe Wally World has it, that does a better job on taking off bugs. Sorry, don't remember the name. It says on the label it is designed to remove bugs better. Of course it costs more, is a different color and smells bad. But it was somewhat helpful at getting them off better than the old blue stuff.
The best plan is to clean the glass thoroughly then apply RainX to help water shed off and bugs don't seem to stick as bad.
However if bugs are bad on the windshield they will be worse on the nose of the MH. If well polished sometimes a used dryer sheet helps remove them &/or Simple Green. I find original Dawn dish detergent mixed with cold water also works ok (mix quite strong). But all that washing makes re-waxing/polishing more often a must too!
The key is to remove them as quickly as possible. This time of year--it is a nonstop ordeal!
* This post was edited 04/26/12 08:42pm by sowego *
2002 Tiffin Phaeton
2005 Malibu Maxx toad
nevadanick
Elko, Nevada
Posted: 04/26/12 07:30am Link  |  Print  |  Notify Moderator
Prestone Bug Wash stuff works amazingly well. I use the Prestone winter wash in the cold season as it removes ice better than anything i.ve tried and the bug wash in the warmer months as it removes the bugs like nothing else. Plus neither one plugs up the windsheild washer spayers.
