RV.Net Open Roads Forum: Dumping problem with Rhino Flex kit, am I doing it wrong?
 > Dumping problem with Rhino Flex kit, am I doing it wrong?
relliott75
Kansas
Posted: 04/24/12 12:39pm Link  |  Print  |  Notify Moderator
Our first ever weekend in a TT was this past weekend we had partial hookups. I read and studied and was confident as we went to the dump site. I put together a brand new Rhino Flex Sewer kit from Walmart but for some reason, the Rhino Flex kit would not hold onto the four notches on the dump pipe of the RV. I slipped the four notches into the four baynet fittings and twisted it, but it wouldn't hold onto the notches as the liquid "surged" while emptying. It sealed and stayed that way if I held it; but it didn't seem to want to stay connected if I dind't keep two fingers onto it. I had the pipe running straight (no curves, dips or bends) from the TT to the dump site.
Is this common or is there some secret or trick this new guy needs to learn?
2007 Jayco 29FBS / GVWR 8800
2010 Dodge Ram 2500 6.7 CTD MEGACab 4x4 Laramie
Kansas City, Kansas
DW, 2 Kids & 100 pound GSD!
mlts22
Austin, Texas
Posted: 04/24/12 12:46pm Link  |  Print  |  Notify Moderator
The 2-4 nibs should just fit into the notches on the Rhino Flex attachment and a twist should secure it well. Is the hose not being able to stay attached? Are there nibs missing, or on the hose, is one of the bayonet "claws" broken?
garysol
Avon Ohio
Posted: 04/24/12 01:02pm Link  |  Print  |  Notify Moderator
Strange..... Mine holds tight to the point that it was a struggle the one time I tried to disconnect it
2008 Dodge Ram 3500 6.7 CTD SRW, Pullrite Superglide 18k.
2012 Komfort 3530fbh 5th wheel with Ground Control
relliott75
Kansas
Posted: 04/24/12 12:58pm Link  |  Print  |  Notify Moderator
The problem is the claws weren't holding well onto the TT hookup. None of them appeared broken, they just didn't really grab and hold when I twisted it on.
navegator
San Diego CA.
Posted: 04/24/12 01:04pm Link  |  Print  |  Notify Moderator
Check the bayonet studs, I bought one and now it is useless, the ears are to small and deform when you try to secure them when you twist them together.
The other problem that I encountered, was that when I tried to lock them, both would twist and the bayonet never latched. I will not purchase another one, going back to my blue hose and fitings.
Hope it helps
Navegator
gotsmart
Aberdeen, WA
Posted: 04/24/12 01:55pm Link  |  Print  |  Notify Moderator
If the Rhino hoses clicks in place easily then look to see if the hose is missing its gasket. The gasket provides the positive seal AND it's thickness usually is enough to require a bit of hand strength to turn the hose fitting so that it clicks in place. The hose fitting should not lock on "super" easy.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
mguay
Northern NH
Posted: 04/24/12 04:15pm Link  |  Print  |  Notify Moderator
Well said! My thought was that the gasket might not be seated completely into the fitting thus not allowing the full twist. I've had mine for 2 years and haven't had any problems~
Real Trucks wear Training Wheels!
RV-1/2n-FUN
FL.
Posted: 04/24/12 02:49pm Link  |  Print  |  Notify Moderator
The CLICK does the trick.
Are you twisting the fitting far enough to engage the detents so it CLICKS? As mentioned above, if no click the gasket could be missing.
bpounds
Whittier CA
Posted: 04/24/12 03:09pm Link  |  Print  |  Notify Moderator
I've got quite a few different brands of fittings, and I have seen some variation in how tight they fit. Some better than others. Anyway, I suggest you get a clear plastic 45° elbow to attach to the outlet, and then connect your Rhino to that. Then you can view and monitor the flow. I found the elbow to be a very good fit on the outlet. The possibility of the seal missing is an excellent point as well.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
wny_pat
Western NYS
Posted: 04/24/12 03:21pm Link  |  Print  |  Notify Moderator
X2. But you still need the gaskets.
