relliott75
Kansas
I thought it'd be better (am I wrong?) to completely drain the fresh water using the low water drain point, but when I turned the valves under the bath sink, absolutely nothing happened. In hindsight, I believe I should have opened the facet tap to release any vaccum pressure? Or do you pull up on the valve to get it to drain?
Do you normally drain all your water if storing it for a week? Do you leave water in the toilet ontop of the flapper too?
Thanks for your insight!
2007 Jayco 29FBS / GVWR 8800
2010 Dodge Ram 2500 6.7 CTD MEGACab 4x4 Laramie
Kansas City, Kansas
DW, 2 Kids & 100 pound GSD!
M GO BLUE
Southgate, MI
In terms of low point drains they are located underneath the trailer and most RV's will have 2 sets (cold/hot) of low point drains (1 on each side of trailer)...
Yes...leave water on top of the flapper to keep it from drying out
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
lanerd
Newport, OR
relliott75 wrote: I thought it'd be better (am I wrong?) to completely drain the fresh water using the low water drain point, but when I turned the valves under the bath sink, absolutely nothing happened. In hindsight, I believe I should have opened the facet tap to release any vaccum pressure? Or do you pull up on the valve to get it to drain?
Not sure what you mean by valves under the bath sink... I would think that those are for turning the water off and on to the sink.
Typically, as M Go blue stated, your low point drain valves will be located under the trailer as they have to be the lowest point of the water system..hence, low point drain. I've never seen two sets of them, but I suppose that can happen.
Yes, most people will completely drain or completely fill the fresh water tanks when in storage. I always completely drain mine.
Hope this helps
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
fla-gypsy
North Florida
No need to completely drain the water from the plumbing lines for short period storage. The low point drains are typically used for draining when winterizing. If you want to drain the freshwater tank that is done directly under the tank (in most cases). Opening a faucet does help them drain. I have no idea what type/style valves your trailer has. They may not be universal. BTW, my low point drains are located under the trailer, are you sure that is what you are turning?
K Charles
Connecticut
My old TT had the low point drains in the floor under the tub. On my new TT they are under the trailer. I only use them when I blow out the lines for winter.
DE88ROX
West Michigan. The other West Coast
M GO BLUE wrote: In terms of low point drains they are located underneath the trailer and most RV's will have 2 sets (cold/hot) of low point drains (1 on each side of trailer)...
that would explain why after pulling both sets of mine (2 each) I had no water in the heater when pullling the drain plug.
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
relliott75
Kansas
I'm referring to the two hoses hanging out of the bottom of the trailer, opposite side from the grey/black drains. I thought in the pdi that hey were to drain water from the fresh water lines in the trailer; I turned the valves under the bath sink (valves to drain fresh water lines in tt) and nothing happened. I'll jump back in there tonight to take another look, maybe they pull up versus turn....
Thanks for the heads up with water in the toilet!
skipnchar
Topeka or somewhere else
Actually when storing for short periods of time I FILL my FW tank to prevent bacteria growth. chlorinated water resists bacteria growth. IN order to drain your lines completely you will probably need to start your pump after opening the LP drains.
Kennedycamper
Algoa, Texas
I put the pink winter storage stuff in the toilet & drains only for Winter storage, and that's the only time I drain water from the trailer. Do leave some water in the toilet during the summer months to keep the seal lubed.
Bonefish
Midland, TX
Out here in west Texas a buddy of mine left his fresh water tank filled. With the heat out here the chlorine is forced out of the water and on his next trip they had a tank full of green water. The algae had taken over. If you have a fish tank leaving the water stand over night will clear of chlorine so you can put fish in it.
We drain the system and FW tank. Black, gray and gally tanks are left with several gallons of water with treating chemicals.
Bonefish
