RV.Net Open Roads Forum: Travel Trailers: Newb - Low water drain point?
 > Newb - Low water drain point?
pasusan
PA
Posted: 04/24/12 04:10pm Link  |  Print  |  Notify Moderator
relliott75 wrote:
I'm referring to the two hoses hanging out of the bottom of the trailer, opposite side from the grey/black drains. I thought in the pdi that hey were to drain water from the fresh water lines in the trailer; I turned the valves under the bath sink (valves to drain fresh water lines in tt) and nothing happened. I'll jump back in there tonight to take another look, maybe they pull up versus turn....
Thanks for the heads up with water in the toilet!
Yeah - try pulling up - that's how mine work. Also - using the low point drains will not drain your fresh water tank - you have to drain that separately - usually with a turn valve on the bottom of the tank.
Trip Pics
"Don't let the sound of your own wheels drive you crazy." JB & GF
Susan & Ben ~
84 Bronco & 90 Award Classic 23 joined with a Hensley Cub
M GO BLUE
Southgate, MI
Posted: 04/25/12 05:21am Link  |  Print  |  Notify Moderator
...and draining the low point drains will not empty your water heater also - that has to be drained separately
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fifth wheel
Onan 5500W Marquis Gold gas generator (HGJAB - 1038D)
MICHIGAN RALLY - July 19-21, 2013 Click here
DE88ROX
West Michigan. The other West Coast
Posted: 04/25/12 03:06pm Link  |  Print  |  Notify Moderator
M GO BLUE wrote:
DE88ROX wrote:
"...and draining the low point drains will not empty your water heater also - that has to be drained separately"
Well i'm not sure about that. At least on my TT. I opened 4 low point drains last week. Two of which are knobs that your turn under the trailer by the tanks. The other two are in the drivers side rear storage under the water heater. Those are the pull-up variety. When I pulled them there seemed to be a little pressure behind them. Later when I unscrewed the plug on my water heater, nothing came out. Not a drop.
All this was done while trailer was sitting level. After I hooked up to put back in storage, I was amazed at how much more water came out.
I stand by what I stated...
Well than, any idea as to how my hot water tank was empty when I unscrewed the plug?
TV- 2010 GMC Sierra Z71 EXT. cab
TT- 2012 Starcraft Autumn Ridge235fb
DE88ROX
Posted: 04/25/12 06:26am Link  |  Print  |  Notify Moderator
LarryJM
NoVa
Posted: 04/25/12 07:03am Link  |  Print  |  Notify Moderator
relliott75 wrote:
I thought it'd be better (am I wrong?) to completely drain the fresh water using the low water drain point, but when I turned the valves under the bath sink, absolutely nothing happened. In hindsight, I believe I should have opened the facet tap to release any vaccum pressure? Or do you pull up on the valve to get it to drain?
Do you normally drain all your water if storing it for a week? Do you leave water in the toilet ontop of the flapper too?
Thanks for your insight!
You can't drain the water in the fresh water tank via the LP drains since the water pump is in line with the fresh water tank. The LP drains will only drain the water from the pipes after the water tank and the HW tank and opening at least one faucet on the hot and cold will help especially for the HW tank.
Larry
M GO BLUE
Southgate, MI
Posted: 04/25/12 07:51am Link  |  Print  |  Notify Moderator
canoe on top
Denver, CO, US
Posted: 04/29/12 06:21pm Link  |  Print  |  Notify Moderator
If I open the low point drains and lift the pressure relief valve on the HWH, the HWH drains. When the water quits running I let the pressure relief lever back down. Can't close the door on the HWH with the lever up.
pasusan
PA
Posted: 04/27/12 05:19am Link  |  Print  |  Notify Moderator
Don't worry DE88ROX, mine empties too.
