RV.Net Open Roads Forum: Crew Cabs are apparently not for carrying Truck Campers
 > Crew Cabs are apparently not for carrying Truck Campers
Page of 9
seraphim
Ohio
Posted: 04/25/12 05:32am Link  |  Print  |  Notify Moderator
TOO BAD THERE ARE NO 1 TON CREW CAB DUALLY TRUCKS TO LEGALLY CARRY ITS WEIGHT!
GMC WT 1 ton CC 4wd DWR rated 5133 lbs. 2WD DWR CC about 300 pounds more.
Wet weight of AF1150 (+ 500 lbs "stuff") is 5097. Pushing it a bit.
* This post was edited 04/25/12 05:46am by seraphim *
2012 GMC 3500HD Crew Cab LB 4x4 DRW with Duramax 6.6 diesel
2013 Palomino Maverick 2902. "Panserbjorn
"I am an armored bear..."
billtex
RI
Posted: 04/25/12 06:18am Link  |  Print  |  Notify Moderator
GMCPU53 wrote:
billtex wrote:
GMCPU53 wrote:
No, did not come with the 7 pin behind the cab, just the standard 7 pin on the back bumper with the towing package. My truck does have the heavy duty front end, all set up for plowing with the heavier springs, wiring, front sway bar etc. thinking of adding a rear sway bar at some point in the future even though it does handle pretty well right now with no suspension mods. Only get a little sway on driveway entrances etc. Joe
You may want to crawl under there and check...they are wire tied on the chassis, between cab and bed....worth a look.
Now you've got my curiosity up. Going to check it out tomorrow morning. Joe
B
These are from the .pdf of my onwers manual...not sure how this will post;
Heavy-DutyTrailer Wiring Harness
Package
For vehicles equipped with heavy duty trailering, the
harness is connected to the trailer mounted to the hitch
platform. The eight-wire harness contains the following
trailer circuits:
• Yellow: Left Stop/Turn Signal
• Dark Green: Right Stop/Turn Signal
• Brown: Taillamps
• White: Ground
• Light Green: Back-up Lamps
• Light Blue: CHMSL*
• Red: Battery Feed**
• Dark Blue: Trailer Brake
*The Center High-Mounted Stoplamp (CHMSL) wire is
tied next to the trailer wiring harness for use with a
trailer, slide-in camper or cap.
**If you are charging a remote (non-vehicle) battery,
turn on the headlamps to boost the vehicle system
voltage and properly charge the battery.
4-91
Camper/Fifth-Wheel Trailer Wiring Package
Notice: Pulling a fifth-wheel trailer with a vehicle
that is equipped with the SS trim package could
damage the vehicle. Do not pull a fifth-wheel trailer
with a vehicle equipped with the SS trim package.
The eight-wire camper harness is located under the front
edge of the pickup box on the driver’s side of the
vehicle, attached to the frame bracket. A connector will
have to be added to the wiring harness which
connects to the camper.
camper/trailer circuits:
• Brown: Taillamps
• White: Ground
• Light Blue: Center High-Mounted Stoplamp
(CHMSL)
• Red: Battery Feed
If your vehicle is equipped with the “Heavy-Duty
Trailering” option, please refer to “Heavy-Duty Trailer
Wiring Package” earlier in this section.
When the camper-wiring harness is ordered without the
heavy-duty trailering package, an eight-wire harness
with a seven-pin connector and separate CHMSL
connector are located at the rear of the vehicle and are
tied to the vehicle’s frame.
4-92
Also helpful;
Auxiliary Battery
The auxiliary battery provision can be used to supply
electrical power to additional equipment that you
may choose to add, such as a slide-in camper.
If your vehicle has this
provision, this relay will be
located on the passenger’s
side of the vehicle, next
to the auxiliary battery.
When using this provision, connection should only be
made to the upper stud (A) of the relay. Do not
make connections to the lower stud (B) of the relay.
The auxiliary battery circuit is protected by a megafuse
located behind the auxiliary battery.
Be sure to follow the proper installation instructions that
are included with any electrical equipment that you
install.
Notice: Leaving electrical equipment on for
extended periods will drain the battery. Always turn
off electrical equipment when not in use and do
not use equipment that exceeds the maximum
amperage rating for the auxiliary battery provision.
Power Winches
If you wish to use a power winch on your vehicle, only
use it when your vehicle is stationary or anchored.
4-94
This seems to indicate that you would only have the auxilary power if you had camper package?
Good luck,
Bill
2006 Chevy D/A CC
Adventurer 810WS
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
mooring product
Pompano Beach Florida
Posted: 04/25/12 06:20am Link  |  Print  |  Notify Moderator
iwon415 wrote:
...and you certainly can't carry a camper with slide on an F250...oh wait...
You SR are crazy..oh wait.
2003 F250 CC SB 6.0 Diesel. ARP studs. EGR delete. NOS. GT 4088 Turbo. Stable loads.
2006 Lance 881 Max.
nycsteve
NY
Posted: 04/25/12 06:41am Link  |  Print  |  Notify Moderator
I have the factory camper certification from Ford on my 2011 crewcab.
Pete_k
Stantonville Tn
Posted: 04/25/12 07:08am Link  |  Print  |  Notify Moderator
Glad our 2500HD crew cab 4x4 short bed shows that tag but with a truck camper. Sounds like the company is covering there butt on this one. That or ford can't haul the load anymore. But this Chevy and Dodge does.
Pete
Ours
2004 Duramax/allison Trans C/C 4x4
2012 Landmark Key Largo
2008 Lund 1825 Pro Guide Tiller, With a Evinrude 90 HP E-Tec
Live near Pickwick Dam and the Tn river
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/25/12 07:27am Link  |  Print  |  Notify Moderator
If you want to carry an extremely heavy camper on a crew cab truck, get an F450/550 or Dodge 4500/5500 cab/chassis crew cab truck. The cab/chassis trucks have 15,000-19,000 GVWR and 11,000-14,000 RGAWR. Plenty of weight carrying capacity to carry the very heaviest campers ever made, and then some...
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
mkirsch
Rochester, NY
Posted: 04/25/12 08:44am Link  |  Print  |  Notify Moderator
Five pages over some CYA boilerplate...
"This truck is not rated to carry a slide-in camper..."
All that means is that if Ford determines the truck broke because you were hauling a camper, they will deny you warranty coverage.
Weight is weight. The truck can't tell if it's got 5000lbs of gravel or 5000lbs of camper back there.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
2BLAZERS
KEIZER, OREGON
Posted: 04/25/12 08:57am Link  |  Print  |  Notify Moderator
RamTC wrote:
dokkema1 wrote:
I was talking to a guy yesterday here in south east utah...he had a 2012 f350 DRW...with a AF 1150 on it brand new...had to upgrade the wheels and tires...19.5 Rickson...he said camper loaded with gear was #5300lbs..center of gravity was still behind rear wheel according to sticker...thse campers are HEAVY..!!!!!
Why this guy need 19.5's with the excess capacity already provided with the OEM tires/rims ?
I've told my wife the truck ''needs'' 19.5s this summer too when the stock factory tires are worn enough to justify new tires
2011 Dodge Ram 3500 4*4 Black dually Laramie 4.10 gears
2011 Arctic Fox 1150 Drybath
2009 Polaris RZR w/fun parts
2011 Polaris Sportsman 550 XP EPS w/stuff
2006 Polaris Sportsman 500 w/stuff
1977 K5 Blazer 1 ton modified
2007 Toyota Camry Hybrid (her car)
Art Schlangen
INDIANAPOLIS,IN
Posted: 04/25/12 09:14am Link  |  Print  |  Notify Moderator
This what mine has special order...
F-250/F-350/F-450 Super Duty®
Camper Package (Option Code 471)
• Increased capacity front springs (2 Up [4x2] or
1 Up [4x4] upgrade over springs computerselected
based on options ordered. Not included
if maximum springs already selected.)
• Rear stabilizer bar (SRW)
• Rear auxiliary springs (F-250)
• Slide-in camper certification
egarant
Mission Viejo CA
Posted: 04/25/12 09:20am Link  |  Print  |  Notify Moderator
That's great, please share with us what the max weight your truck camper can be.
Thanks!
Page of 9
