RV.Net Open Roads Forum: Onan 7.5 Diesel Genset Fuel Pump inflated price *RESOLUTION*
 > Onan 7.5 Diesel Genset Fuel Pump inflated price *RESOLUTION*
vacuumbed
Salt Lake City, Utah
Posted: 04/24/12 05:26pm Link  |  Print  |  Notify Moderator
I hope the answer to this thread will help people.
Onan/Cummins is known to buy parts from other suppliers, put them in their box and charge an inflated price for it. I have seen this with Champion spark plugs for their gas gensets.
So I need a fuel pump for my Onan 7.5 DKDFJ diesel genset. It has the Facet one seen in the pic, it is leaking. Called the dealer here and it's part number 149-1828 and runs $180. These Facet pumps can be had for less than $90 on eBay.
The questions is... How do I know which one has the right spec?
* This post was edited 05/02/12 07:04pm by vacuumbed *
Old-Biscuit
Across the USA
Posted: 04/24/12 06:06pm Link  |  Print  |  Notify Moderator
Ah Ha.....therein comes the extra $90 up charge.
Cummins knows the correct specs.
Have you tried checking with FACET.
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
vacuumbed
Posted: 04/24/12 06:24pm Link  |  Print  |  Notify Moderator
I am going to call Facet in the morning. I am also going to pull the pump tonight and see if there are any numbers on it.
jag73e
Daphne, AL
Posted: 04/24/12 06:50pm Link  |  Print  |  Notify Moderator
This from a google inquiry, put part # in the search. Lots of info there.
"I had to replace 12 v fuel pump on Onan MDKD 8kw generator,Onan #149-1828. After numerous calls I got the pump at PEP BOYS Auto approved for marine diesel engines, # Facet USA 42370 for $82.00, It is identical, Hope this helps someone.
Will be leaving Aventura Fl. For Whitby Ontario Canada April 22.
Cheers Stewart"
W4RLR
Sewanee, Tennessee
Posted: 04/24/12 07:18pm Link  |  Print  |  Notify Moderator
I found the local CarQuest shop could cross-reference most Onan filters and pumps with CarQuest units, identical in every way except price.
Richard L. Ray
SSgt USAF (Retired) Life Member DAV
W4RLR 146.52 mhz
2005 Ford F-250 Lariat Crew Cab
1995 Jayco Eagle 277RBSS fifth-wheel
"Never ask a man what kind of computer he drives. If it's a Mac, he'll tell you. If not, why embarrass him?"
Tom Clancy
vacuumbed
Posted: 04/24/12 08:28pm Link  |  Print  |  Notify Moderator
Cheers Stewart"
The part number 42370 comes back to a filter kit for the pump.
2bzy2c
California
Posted: 04/24/12 09:14pm Link  |  Print  |  Notify Moderator
I suppose for the extra $90, you will get some sort of security knowing you have the right part.
Ebay is known for their warranties and return policies.
My advice is worth exactly what you paid for it.
J Walker
Oakton, Va
Posted: 04/24/12 09:58pm Link  |  Print  |  Notify Moderator
Shop around. Some dealers have incredible markups. They must thing that we are captive customers. There are not that many dealers out there but you can shop around or buy online. I was charged $180 for an upper radiator hose that I later discovered other dealers sold for $80.
Jim Walker
2000 34' Damon Ultrasport DP
2009 Malibu
Brake Buddy
sc3283
St Louis
Posted: 04/24/12 10:42pm Link  |  Print  |  Notify Moderator
that type pump was sold years ago by Carter Carb
04 D-Max Crew Dually
96 Monaco Dynasty 36'
vacuumbed
Posted: 04/25/12 04:35am Link  |  Print  |  Notify Moderator
The only number I could find on the pump is 40131E
