RV.Net Open Roads Forum: Class A Motorhomes: Mounting Solar Panels
 > Mounting Solar Panels
JimGo
Glendale, AZ
Posted: 04/24/12 05:37pm Link  |  Print  |  Notify Moderator
2007 Pace Arrow-
How have others mounted solar panels? These will not be on a tilt frame.
I have 2 panels and z brackets to use for mounting to roof.
What is under the rubber?
Thanks
Jim and Terri
2007 Pace Arrow 37C
W22 Chassis, 8.1 Vortec, Banks PowerPack, Allison 1000
2012 Chevy Nox LTZ AWD
Black Lab "Jessi"
Helimech
Chino Valley
Posted: 04/24/12 06:04pm Link  |  Print  |  Notify Moderator
Just picked up a 2nd panel myself. I don't mess with the roof at all, I let the pros handle it. Small cost for a little piece of mind.
pianotuna
Regina, SK, Canada
Posted: 04/24/12 07:06pm Link  |  Print  |  Notify Moderator
Hi,
Usually thin luan plywood. Try to get the diagram of the roof support "beams" or "trusses" from the manufacturer. (I'm not sure of the correct term).
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
JimGo
Glendale, AZ
Posted: 04/24/12 07:13pm Link  |  Print  |  Notify Moderator
PianoTuna- Thats on my list tomorrow. So what do people do if the z brackets don't line up?
pianotuna
Regina, SK, Canada
Posted: 04/24/12 07:35pm Link  |  Print  |  Notify Moderator
Hi,
My installer rolled his own.
wa_desert_rat
Central Washington State
Posted: 04/24/12 07:38pm Link  |  Print  |  Notify Moderator
This may not apply to you, but for owners of fiberglass roofs (that have not been painted) you can use very high adhesion tape for mounting and avoid putting holes in your roof. The tape isn't cheap, but you don't need much of it. It's used on jet airplanes to hold items onto the plane's aluminum skin.
If your roof has been painted the adhesion is only as good as the paint's bond to the gelcoat. But if unpainted the gelcoat is part of the f/g roof and you can use the tape.
I'm about to order 4 solar panels and will be mounting them this way. I couldn't believe it when I was told about it but many users have assured me that it works.
Craig
royST
ann arbor
Posted: 04/24/12 07:40pm Link  |  Print  |  Notify Moderator
I'd personally go with Helimech's suggestion. We had our solar panels installed for us when we got them. It definitely added to the cost. But it was worth it. No problems with it yet so far.
smkettner
I used a #10 stainless deck screw.
675 watts solar
robatthelake
Vancouver Island
Posted: 04/24/12 07:54pm Link  |  Print  |  Notify Moderator
I use Well Nuts and a lot of Dicor to seal the Bolt heads!
Rob & Jean
98 Dutch Star Diesel Pusher ..92 Tracker 4X2
JimGo
Glendale, AZ
Posted: 04/24/12 08:23pm Link  |  Print  |  Notify Moderator
Here is the size of my 2 panels 77.01 x 39.13 x 1.97. Does this make any difference how they are mounted.
The reseller told me to mount to roof framing. Not sure it will match up so looking for options.
