RV.Net Open Roads Forum: Tech Issues: Battery at 50% what does that mean
 > Battery at 50% what does that mean
Rmcgrath53
Howell
Posted: 04/24/12 06:44pm Link  |  Print  |  Notify Moderator
I am just getting my stuff ,here is what I got
main lights led.
Morningstar 6o amp mppt controler with remote
2000 xantex inverter
100 amp fuse ,150 amp fuse
60 amd disconect
4 140 watt panels
need to get 4 6 volt batteries
How will I know when my batteries will be at 50%? Is there a led or alarm that can be set?
h
* This post was edited 04/24/12 07:37pm by Rmcgrath53 *
2008 keystone Everest 345s re
2002 F350 4x4 7.3 diesel crew cab dually. 135,000 miles extra leafs.
Banks stinger/ with an edge attitude set at tow
prodigy 3p curt 20k hitch
trail air suspension trail air pinbox
2 e2000 honda w parralel kit
560 watts solar
msiminoff
Silicon Valley, CA
Posted: 04/24/12 06:56pm Link  |  Print  |  Notify Moderator
TRIMETRIC
'04 Alpenlite Saratoga 935, 326W of solar, 300Ah Odyssey batt's, Trimetric, Prosine 2.0
05 Ram3500, Cummins, Goerend Trans, Vision 19.5 w/XDE's, Dynatrac Hubs, RR airbags w/ping tanks, Superhitch, Roadmaster Swaybar, Thuren trackbar, RS9000XL/MyRide
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/24/12 07:09pm Link  |  Print  |  Notify Moderator
http://www.bogartengineering.com/support
Gadget Guy
Calgary
Posted: 04/24/12 08:46pm Link  |  Print  |  Notify Moderator
Another vote for a Trimetric.
westernrvparkowner
montana
Posted: 04/24/12 09:06pm Link  |  Print  |  Notify Moderator
Battery at 50% can mean two things. For some, it will mean the battery is half charged, for others it means it is half discharged. Only you know what it means to you.
1L243
Astoria, Oregon
Posted: 04/24/12 10:18pm Link  |  Print  |  Notify Moderator
Actaully at 50% your batteries are at about 12.05 volts. I try not to let my batteries get below 12.1 volts. I bought an inexpensive volt minder. You can set it to beep at what ever level you want.
Here is some reading...
http://wiki.uiowa.edu/display/greenergy/Battery+Systems+Overview
* This post was edited 04/24/12 10:45pm by 1L243 *
2011 Work and Play 30WR. Added 2nd AC, four deep cycle batteries.
opnspaces
San Diego Ca
Posted: 04/24/12 10:41pm Link  |  Print  |  Notify Moderator
1L243 wrote:
Actaully at 50% your batteries are at about 12.5 volts. I try not to let my batteries get below 12.1 volts. I bought an inexpensive volt minder. You can set it to beep at what ever level you want.
1L243, You've got your decimal wrong. 50% is 12.06 volts not 12.5 which is 90% charge.
As far as knowing the battery state of charge, I pull out the old multimeter and measure it.
1996 Suburban 4x4. 350, 4.10 3/4 ton
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
1L243
Astoria, Oregon
Posted: 04/24/12 10:46pm Link  |  Print  |  Notify Moderator
Ooops! Thanks...
2oldman
Winchester WA
Posted: 04/25/12 10:54am Link  |  Print  |  Notify Moderator
If the inverter comes with a control panel, it will read voltage.
nstate
usa
Posted: 04/25/12 10:40pm Link  |  Print  |  Notify Moderator
msiminoff wrote:
TRIMETRIC
X3
