RV.Net Open Roads Forum: Truck Campers: Honda generator and A/C
 > Honda generator and A/C
dlduke01
east
Posted: 04/24/12 09:48pm Link  |  Print  |  Notify Moderator
I have a Honda 2000i and Dometic 13500btu a/c. It will make the a/c come on but won't cycle through. I read on here that alot of guys have a 13500btu a/c and it works great. Please tell me if I'm doing something wrong or if I need to change something. I don't know if it makes a difference but the genny is about 5-6 years old but has only been ran a few times. When I got it I had to clean the carb because it had been sitting so long.
thanks
2007 Ford f 350 crewcab longbed srw 4x4 4" bds lift w/ 35" Dick Cepeks
1995 lance squire 185
2003 jeep rubicon 4.5" with a bunch of extra bells and whistles
Artum Snowbird
Campbell River, B.C., Canada
Posted: 04/24/12 09:55pm Link  |  Print  |  Notify Moderator
It seems 13.5 btu units are just about the limit of the Honda, and it depends a bit how the A/C starts. You might look into getting a soft start setup, it basically scales the load up just a bit softer than a full start and lets your Honda pick up the load.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
Buzzcut1
Norcal
Posted: 04/24/12 10:21pm Link  |  Print  |  Notify Moderator
that my friend is the reason that a whole bunch of us have the Honda 2000 and a Polar Cub 9200 instead
03 F350 Diesel 4x4 Crew Cab long bed, 08 Lance 1055, Rancho 9000xl, Air Lift air Bags, Torqlift tiedowns,stable loads, super hitch, 48" super truss, Toyo 285/75R16 Opencountry HT
3 tons
CA.
Posted: 04/24/12 10:49pm Link  |  Print  |  Notify Moderator
Make sure that the Honda is not in 'ECO' mode and reduce any other loads in your camper (shut off breaker to converter/charger, put refer on LPG, etc).
Raften
Northern Calfornia
Posted: 04/25/12 12:18am Link  |  Print  |  Notify Moderator
I always raise an eyebrow when people say their 2000 works just fine with a 13500. Mine will run it just fine at sea level and temps below 75 F but won't at 2000 feet and temps over 80 F. It will work for ten or so minutes but then the heat overwhelms the gen set.
dieseltruckdriver
Black Hills of SD
Posted: 04/25/12 12:30am Link  |  Print  |  Notify Moderator
I have a 13,500 btu Coleman and a Honda EU2000i and mine won't do it. I have tried twice. Once at 1300 feet, and around 80 degrees.
I did try a Honda EU3000i once and it would work at 5800 feet, even short cycling, but I have a hard time lifting it. Probably going to buy another 2000 if things work out this summer.
1995 F-250 7.3 Powerstroke
2000 Arctic Fox 27-5L
SWD
Land of Living Skies
Posted: 04/25/12 06:18am Link  |  Print  |  Notify Moderator
Need two units in parallel to power a 13.5 AC
twodog
arizona
Posted: 04/25/12 06:47am Link  |  Print  |  Notify Moderator
Have you properly sized your power cord? Gauge and distance make a huge difference. There are a number of charts available that will tell you what's recommended to minimize the loss to 3-5%. I had a similar problem. Found out my cord was too long.
2dog
17' nash,pv,axleflip,hd sus w/shocks, yamaha gensets
t4r, arb goodies
halibutman214
Oregon
Posted: 04/25/12 07:51am Link  |  Print  |  Notify Moderator
I don't know what your reading but, "it works great" raises more than an eyebrow with me. The thing you need to change is your generator. My Polar Cub, "works great", but any bigger A/C won't. I'm looking at getting one of the new Yamaha EF2400 for this very reason.
2008 Dodge Ram 6.7 Laramie SRW SB
2012 Keystone Passport 26BHWE
2009 Lance 830 with Tent foldout
20' North River Seahawk Boat
2005 Honda VTX1300
BradW
Mayor of Flat Rock
Posted: 04/25/12 07:57am Link  |  Print  |  Notify Moderator
I have a Honda EU2000i and Dometic 11,500btu a/c. Will run the a/c if the gen is not in econo mode and nothing else is running. Even then the gen is running wao to handle the a/c.
Brad
Internet forums only exist to serve their members; never the other way around.
1996 Lance 500 and 2006 F-350 PSD 4X4 DRW
Our Truck Camper Photos
