RV.Net Open Roads Forum: Tow Vehicles: EOS..Engine Oil Supplement
Search only in Tow Vehicles
 > EOS..Engine Oil Supplement
DDD/MT
Montana
Posted: 04/24/12 09:53pm Link  |  Print  |  Notify Moderator
Has anybody had the fatal tic tic of a valve lifter going south because of the lack of zinc in dino oil?
DDD/MT
Turtle n Peeps
California
Posted: 04/24/12 11:04pm Link  |  Print  |  Notify Moderator
DDD/MT
Most cams are roller now days and you don't have to worry about chewed up cams and lifters.
outside the fire"
Dave H M
IL
Posted: 04/25/12 08:01am Link  |  Print  |  Notify Moderator
no, never heard of it locally
amxpress
Clayton, NC
Posted: 04/25/12 05:52am Link  |  Print  |  Notify Moderator
Haven't experienced it personally, but have read about it in Hot Rod & Car Craft.
I've used Z-Max with success on some engines to add a little more Zinc to the crankcase. Won't use it in my Cummins, though; might mess up my paticulate matter convertors or diesel cat cons. Besides, I've had good luck with Amsoil.
You having lifter noise?
2007 Dodge RAM 2500 Quad Cab w/6.7 Cummins
2013 Palomino Columbus 320RS
Reese 15K Pro Series manual slide
Prodigy
Firestone Air Bags
Champion 3500 genny
M.I.L denied parole! Yeah!
tempforce
Pacific Wonderland (in the summers)
Posted: 04/25/12 06:36am Link  |  Print  |  Notify Moderator
if the lifter ticks first thing in the morning then gets quiet, your o.k. it's just oil leak down.
if it ticks all the time, it can be one of the following:
a) the mechanical parts within the lifter are stuck/collapsed, it needs replaced... i would change them all...
b) the cam, lifter rollers, valve train has excessive slop and the valves need adjusted. this may be done with a adjustment of a nut/bolt, shaft, and/or spacer replacement.
sometimes just using a thicker grade of oil will take up the slack..
somewhere in the texas 'lost pines'
'08' Dodge mega limo-cab, 409, kelderman rear air ride, max brake controller.
'02' 34' Holiday Rambler TT, the Gypsy Wagon.
'83' Ford Ranger with a 2.2 Diesel, little smoke
'56' F100 project truck
thomasmnile
Deltona, Fl.
Posted: 04/25/12 07:50am Link  |  Print  |  Notify Moderator
Is it possible the valve "tic" is from inadequate lubrication due to clogged oil passages to the top end of the engine??
ACZL
UPstate,NY
Posted: 04/26/12 12:58am Link  |  Print  |  Notify Moderator
Try adding some Motorkote to your oil. Now avail at Wal-Mart. Web site is www.motorkote.com
2003 F250 SD,CC,4x4,SB,AT,Lariat,6.0PSD
2006 Cedar Creek Silverback 33 LBHTS "Custom"
Member of The Cedar Creek RV Club
"Creekin' in the Summer"
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
bartlettj
Forest Grove, OR
Posted: 04/25/12 11:10am Link  |  Print  |  Notify Moderator
From what I understand, the ZDDP is most important during the breakin period. If your engine is already broken in, it is unlikely that you will miss it.
ib516
Up here!
Posted: 04/25/12 10:05am Link  |  Print  |  Notify Moderator
You need to do some reading on the forums over at http://www.bobistheoilguy.com/forums
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
hawkeye-08
Northwest
Posted: 04/25/12 08:54am Link  |  Print  |  Notify Moderator
Yes, I had the cam go flat in my 73 454 pickup and have the rebuilt engine ready to go back in, yes, it will use oil made for the flat tappet engines. It was a costly mistake to use modern oils. I figured out the cause after I got the engine back or I would have looked into changing to roller lifters.
