RV.Net Open Roads Forum: Mattress Lift Gas Springs - Upgrading Problems
 > Mattress Lift Gas Springs - Upgrading Problems
huntram
Fulltiming in the RV
Posted: 05/01/12 11:27pm Link  |  Print  |  Notify Moderator
I had the same problem. When I added the 4" memory foam the bed was heavy to lift and would not stay up on it's own. I replaced with 150lb 26" props. The plywood was going to shatter if I forced it closed! I put the mattress back on which was hard in the up position. Still no go. I finally put the foam on also which was near impossible in the up position. All of a sudden with all the weight distribued evenly all was GREAT! It closed and opened easily and stayed open with no problem. Now that it has been closed. I think it would be no problem without the foam. It was just that FIRST time that was a bear!
Just make sure you evenly put all your weight back on before you try and close it!
B
Our traveling blog:Brian and Patty's Awesome Adventure
2004.5 Dodge Ram 2500 Quad Cab 4-door CTD, , 2011 Carriage Cameo 32FWS 5th wheel. Piaggio BV250
CincyGus
Cincinnati
Posted: 05/02/12 07:58am Link  |  Print  |  Notify Moderator
I have not done this mod yet but the one thing I have seen from the people who have and posted about it was that most of them beefed up the wood structure under the beds by adding a 2"x4" to the frame rails where the gas shocks mounted. Seems like adding this extra support allowed them to use more substantial mounting hardware for these much stronger gas shocks. Then it's all about getting the right mounting angle to make the bed just more than neutral and where it will stay up or down properly.
Easy for me to say as I have not done it yet but plan on it soon. I just thought I'd offer what I have gleamed from the numerous posts I've seen on this in hopes it helped.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
TxTiger
North Texas
Posted: 05/02/12 08:20am Link  |  Print  |  Notify Moderator
My supports work great with the OEM mattress and a 31lb topper. However, the wood, let me re-phrase, the particle board, supporting the matress is bowed up at the side of the bed from the pressure of the shocks. The gas shocks don't seem to be the best way of doing this. I don't think anyone would be opposed to a factory manual method like those whose use a fold down support. I think I will replace the bowed particle board with some thicker plywood, and either still use the gas shocks since they work well with what I have, or do the manual modification.
2000 F250, 7.3 PSD, 6 speed manual, CC, SB
KZ 27TH Toy Hauler, 5,700 lb dry weight/8,000 lb GVW.
2010 Triumph Tiger 1050
2012 Triumph America
2009 Suzuki DRZ 400sm
mr300ce
Mojave Desert, Ca
Posted: 05/02/12 09:19pm Link  |  Print  |  Notify Moderator
I think I would hurt my back if I tried to lift the mattress up without those gas struts to assist. It is heavier with the extra foam I added, and the mattress won't stay up by itself with the original struts. But with the leg I added to keep it up when needed, all is well.
Fulltime livin' & lovin' it in '94 Bounder 32h.
Chevy 454ci Retire in 3yrs.
ghekiere1
Chester Montana
Posted: 05/02/12 10:16pm Link  |  Print  |  Notify Moderator
opnspaces wrote:
Put the old struts back on the bed. then move either the top or bottom mount a little bit to make them stand more vertical. This will give them more lifting force. Make sure that they still have enough clearance to allow the bed to fully close.
Is there a 100 pound strut you could try?
This is exactly what I did to mine. I moved the top about 1.5 inches and it was plenty to hold the mattress in the upright position. and it was free. just a little time. also like was said. make sure you can put bed all the way down when finished.
1997 2500 Power Wagon 8.0 Liter V-10 Long Box
Prodigy P3 Brake Controller
2010 Starcraft Autumn Ridge 297 BHS
Diplomat Don
Moorpark, Ca
Posted: 05/03/12 12:02am Link  |  Print  |  Notify Moderator
I originally added a second set of lifts to mine and tore everything up. I went back to a single one each side and built a drop down support to use when the bed was up.
I later tackled the job again using double pistons, but welded up a frame for the bottom and some heftier brackets for the plywood mattress base.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2012 Chevrolet Silverado LTZ CrewCab 4WD
2013 Polaris RZR 800 LE
az99
Pa.
Posted: 05/03/12 05:09am Link  |  Print  |  Notify Moderator
Very nice design and workmanship.
Vulcaneer
Northern New England
Posted: 05/03/12 01:47pm Link  |  Print  |  Notify Moderator
1X4X36 prop, hinged at top. Similar to the broomstick design. Cheap, strong, functional, quick, reliable, won't slip out of position, always there when you need it, no looking for it, no stress on particle board bed frame.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto, Ultimate Lariat pkg
2011 Open Range 393RLS 14,250 GVWR
Pullrite Super Glide 18K
dakonthemountain
Crestline, California
Posted: 05/03/12 04:29pm Link  |  Print  |  Notify Moderator
Maybe I'm missing something here, but couldn't you just replace the strut brackets/bolts with stronger ones matched to the struts? That's what I did in a TT that I had...
Dak
1995 Weekender model 910 extended cabover
Calvin, the 1996 creampuff Chev Silverado 3500 extended cab dually
Escapee #22435
