RV.Net Open Roads Forum: Suggestions requested re: end of life for my 5th wheel
 > Suggestions requested re: end of life for my 5th wheel
Jim-Linda
Livingston, TX
Posted: 04/25/12 08:27am Link  |  Print  |  Notify Moderator
FWIW, ours is a '98 HH CE. We have yet to see "end of life". We do keep up with maintenance, currently removing all of the caulk from the bay window area "5 windows" to re-caulk. We recently replaced the Kenmore stack W/D, timer started doing strange stuff, replaced TV with LCD, going to replace the vinyl insert in all strips, roof is Eternabonded , replaced Dometic fridge with Whirlpool couple of years ago, etc.
After the re-caulking, we are going to apply NewGlass2 to bring the gelcoat back, so again, no plans to discard a perfectly good trailer.
Jim
B W M
Princeton IN.
Posted: 04/25/12 08:43am Link  |  Print  |  Notify Moderator
I live in IN and there is a lot of people buying them to put on the rivers here that way they move them when the rivers get out!
03-3500 laramie 4x4 6 speed 3.73 gear Jake brake triple piller isspro gauges 04-38ft fifth wheel Prowler AX-6 100gal in bed fuel tank volant air intake tool box Utra-Fab air deflector Tom Tom 720
cefloyd 1961
kentucky
Posted: 04/25/12 09:51am Link  |  Print  |  Notify Moderator
Here in Kentucky people are always looking for old campers to set up at the lake and hunters also look for them I had a friend buy a old tag along for 3 grand a few years back and it was in bad shape nothing worked on it not even the heat so there is a market for old campers you just have to put it out there and I will also jump on the Craigs list bandwagon with every one else dont just put it in your area put it in many states and areas on there Good luck and I hope God Bleses you !!!
2006 f350 superduty 6.0.. 2012 sandpiper 345RET loaded
mowermech
Billings, MT
Posted: 04/25/12 10:41am Link  |  Print  |  Notify Moderator
If all else fails, I would strip it down, sell what is salable, recycle what is recyclable, take the rest to the dump, and transform it into a very nice flatbed trailer.
Then I would remove all identifying marks, and title it as a 2012 Homebuilt trailer, with a new VIN assigned by the state, properly stamped into the frame.
A flatbed like that should bring $2500 or more, easily, or would be quite useful as a keeper.
Good luck.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
wandering1
Posted: 04/25/12 10:44am Link  |  Print  |  Notify Moderator
Take it to a used RV dealer and see what they will give you for it.
HR
Too Young to Retire
Sun Diego
Posted: 04/25/12 03:29pm Link  |  Print  |  Notify Moderator
Take it out to the desert and torch it.
Chevy 3500HD Crewcab, SB, Diesel pulling a 36' Cameo
hyattjlbb
Minot, ND
Posted: 04/25/12 08:12pm Link  |  Print  |  Notify Moderator
Bring it to North Dakota and sell it to these guys up here working for the oil and no place to live. Could get 3X what it is worth and they WILL PAY IT! Crazy as it sounds, very true for semi-permanent with no available housing left around here ans ome of them are living in much older and more decrepit RV's.
2011 Jayco Eagle 365BHS
2007 Chevy Silverado CC/SB 2500HD, Max & Alli
Beautiful Wife of only 17 Years
Boy - 15yrs, thinks he's 20
Boy - 8yrs
Bachus
Stratford, Ontario, Canada
Posted: 04/27/12 07:55pm Link  |  Print  |  Notify Moderator
I have often wondered what happens to old fivers. I'd love to buy an old unit and turn it into a nice fifth wheel flatbed. It would be perfect for hauling my tractor, and other long items that I need in my business.
Dean and Tracy Bachellier
Isobel,Evelyn, and Stuart
2012 KZ Durango D355BHS quad bunk with 5 slides
HiJacker 16K double pivot slider
2011 RAM 3500 SRW Crew Cab 4X4 CTD
"It's five o'clock somewhere...."
rasteck
Northern California/East Bay
Posted: 04/27/12 08:50pm Link  |  Print  |  Notify Moderator
We donated our '92 Rockwood Wildwood (26' with some dry rot) to the Polly Class Foundation and were able to write off a $2200 donation.
Just a thought.
2000 Ram 2500 SLT/Laramie 24V CTD 2WD QCSB PacBrake, Smarty
2011 Colorado 320BS-FW 36'
EZ Flex + wet bolt
Curt E5 with R5 slider, Prodigy P3
Air Lift 5000's, Load Controller II
CleanDiesel
Norton, Ohio
Posted: 04/27/12 10:25pm Link  |  Print  |  Notify Moderator
Hey Gang,
To answer the main question being asked, "What is wrong with it?", here's the answer.
The biggest issue is that water got into the living room windows and caused wood rot. So it would take some real "teardown" to get to the wood and replace it. Given that everything these days is "vacuum bonded", I am guessing that would significantly screw up the exterior fiberglass layer. And of course, even though the roof doesn't leak, a new rubber roof is needed on a camper from 1995.
If that #1 issue could get fixed, then actually you're just down to a couple appliances. The frig only works half the time, and the water heater is pretty much done (won't light anymore). But the A/C works great, stove is fine, water pump....you get the idea.
The frame and mechanics are very sound. The wood in the camper, not so much.
REALLY good suggestions from the community as always. My that picture of a nice Class A going up in flames is a sad sight. Hope no one was hurt.
TV: 2007 Dodge Ram 3500 SLT Quad Cab 4x4 Dually 6.7L Cummins Auto w/3.73s & Prodigy
TT: 1995 Damon Escaper 5'er 36RLB
