I have a 2003 Mallard and I just got back from camping. While at the CG I notice that I had a water leak coming from were the hose hooks up to the TT, not form the front of the hose but from behind the screw in nob.. Could this be that the washer is worn out or maybe I need to replace the part were the hose hooks up to it?
Thanks in advace to all>>>>
2005 National Sea Breeze LX 8321
2010 Forest River Salem 403FB-Destination Trailer
2009 F150 4X4 Crew Cab
2006 HD Heritage Softtail
1999 Sweetwater Challenger 30hp (Pontoon)
Takes the screws out and in behind the wall there will be a check valve in the line. When you pressurize your system, this check valve prevents the water from coming back out the same way it went in.
It's a part of winterizing that many don't get right, and you might find that the check valve just needs to be replaced, about a five dollar part and five minutes. It just screws onto the line and is about an inch long.
Mike and Carole
2007 Snowbird 9'6" Super Slide
2005 16.6 Double Eagle
2000 F350 7.3 SC 4X4
previously 8'10" Snowbird Camper
2006 Triple E Regency 27 foot SXL SOLD!
I carry a dozen or so spare rubber washers and change them out every three or four camping trips to prevent water leakage where the pressure water connects. Cost is next to nothing and it prevents the annoying drips.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR - 2004 F-150 HD (Traded after 80,000 towing miles) 2007 Rockwood 8314SS 34' travel trailer
