wcraft
Severn, MD
Lynx levelers here too. These are probably the best purchase we made when we bought our TT. We use them under the tires to level the trailer, under the stabilizers when not on pavement, and under the tongue jack.
Since most (if not all) TT don't come with a jack for changing a flat tire, the lynx levelers can be good for riding one wheel up just enough to give the other wheel some room to come off.
They are light-weight, compact and fit nicely in a truck tool box or the TT cargo hold. They don't slip when the ground is a little wet, or just smooth.
The only "problem" we've had with them is that the color fades significantly in the sun. But that's a minor thing for all the good these do.
2011 Keystone Passport 3220BH GT Ltd. Edition
2012 Chevrolet Silverado LT Crew Cab 4x4 w/6.2L and Max Tow Pkg
2002 Chevrolet Suburban LT/Autoride & AirLift air springs (Traded)
Reese Strait-Line WD with dual-cam sway control
My blog - www.CampDestinations.com
skipnchar
Topeka or somewhere else
I cary a combination of 2/6 and 1/6 planks. Some are 4' in length for use under both axles and others are 12" long for use under individual axles. I DO carry Lego style levels but don't often use them for leveling. They make a quickly set up ramp for use if I need to raise a wheel for a tire change.
phenrichs
Sioux Falls, SD
SWD wrote: Use Lynx Levellers. Used to haul pieces of lumber around but these blocks are by far the best. Havnt wrecked one in the 6 years I've had them.
Yep, me too. Takes 3 packs of them to level safely at the house because of the angle of the street. Used to use boards but when you drive up on one end the other end wants to pop up and I was always afraid of wrecking the under carriage.
2006 Ram 3500 Megacab Cummins
2012 Keystone Sprinter 311BHS
Chuck&Gail
In the Colorado Mountains
We use leveler blocks. Sure not risking my frame! Blocks are clean, simple, light, easy to clean. So far they've worked great for over 100,000 miles.
I used the wood ones I had to start to make a fire.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
jackandh2o
Golden Valley, Arizona
We have been using the blocks from Wally World for about 6 years now.
Like the weight, makes them easy to use and store.
JLTN_James
Colorado
Another Lynx user here. I have one set but am considering getting a second. After the axle flip on my PUP, one set occasionally doesn't quite get the job done; I usually have to put one or two beneath the stabilizer jacks.
2004 Toyota Tundra SR5 (V8, 4WD, TP, TRD)
2005 Fleetwod Allegance with axle flip
Honeywell 2000i Generator
Me, DW, DS, DD, Dog & Camping Kitty
Tom Trostel
Arlington, TX
BAL light trailer tire leveler
jaycocamprs
Ringgold Georgia
Usually it’s just the orange wedges, but some times it takes a little more
2005 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
MichDoc
Michigan
Anyone have any experiences or thoughts about these Level-upp ramps, or the Fiama ramps? I was thinking about those to avoid having to constantly "assemble" the Lego style blocks.
jaycocamprs
Ringgold Georgia
I like the wedges that I use. We have the big level on the pin, just back up till the ball centers. I like them because they are not stepped. We got them at Camping World some years back, I think they still sell them.
