I've had my truck since September. Yesterday I took about 450 sq ft of carpet and pad to the dump. I'd guess that load weighed less than 300 pounds.
Looking at the receipt, I noticed that the dump has the weight of my truck listed as 9560 pounds. Could that be right? It was me, my 3 Weimaraners (190 pounds), topper on the truck and 90 gallons of fuel.
I seem to remember that my last truck (in signature also) was around 7300 pounds. Could this new truck really weigh over 9000 pounds??
Does anyone else have a weight slip on their 3500 DRW crew diesel?
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
With hitch and tool box, people and dogs, 8500 lbs
2008 F350SD V10 with an 2012 Arctic Fox 29-5E When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
That weights probably right on...the dogs and fuel are 1000lbs alone! I was shocked the first time I put my SD on a scale...between the tank, tool, hitch, fuel, more tools, and stuff you can add a lot of weight! I have also heard stories of guys hitting scales across the street from each other with their fivers and finding 1000lb discrepancies! Anyhow-I can't seem to remember exactly how much my F350 weighs real wet(I believe somewhere just under 10K)-but I do know the 550 was 13885 the last time I hit a scale with the fiver...yes-including the pin!
A big diesel DRW is going to start out at over 8000lbs these days.
Add a topper (300lbs), you (?lbs), Weimaraners (190lbs), and 1000lbs of fuel and tank... That's 1500lbs right there.
2002 Chevy 3500 DRW 8.1L/Allison
2000 Palomino B1500
...and the reason why I need a DRW to haul a Palomino:
2004 United 7x14 tandem axle enclosed toy trailer
2011 PJ 8x20 7-ton deckover equipment trailer
