RV.Net Open Roads Forum: Tow Vehicles: What Does your DRW Truck Weigh?
Search only in Tow Vehicles
 > What Does your DRW Truck Weigh?
Farmer David
Mattoon, ILL.
Posted: 04/25/12 03:43pm Link  |  Print  |  Notify Moderator
That weight is probably right my truck is a supper cab I had 90 gal of fuel on my fifth wheel hitch and probably 200 lbs of tools in a box and my truck weighed 9200
2013 F450 King Ranch CC Long Box
60 Gal RDS Tank
20K B&W OEM Hitch
2013 Lifestyle 37IK
Bionic Man
Colorado
Posted: 04/25/12 04:50pm Link  |  Print  |  Notify Moderator
Well, I guess I now have a better idea of why I get the MPG I do. Love the truck, but it is living up to the nickname my wife gave it - the Queen Mary.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
tgreening
Ohio
Posted: 04/25/12 08:04pm Link  |  Print  |  Notify Moderator
Bionic Man wrote:
I've had my truck since September. Yesterday I took about 450 sq ft of carpet and pad to the dump. I'd guess that load weighed less than 300 pounds.
Looking at the receipt, I noticed that the dump has the weight of my truck listed as 9560 pounds. Could that be right? It was me, my 3 Weimaraners (190 pounds), topper on the truck and 90 gallons of fuel.
I seem to remember that my last truck (in signature also) was around 7300 pounds. Could this new truck really weigh over 9000 pounds??
Does anyone else have a weight slip on their 3500 DRW crew diesel?
2008 F-450 with me, a full bag of fuel, and nothing else, tipped the certified scales at the nearest truck stop at 9,400 lbs.
2008 Ford F-450 "Lil Beasty"
2011 Heartland 3950 "Big Beasty"
1970 DW Made in Japan "Big Bossy"
2005 DD Made in Ohio "Big Pain"
2007 DD Made in Ohio "Lil Pain"
2004 GR Bahzu the dog "Big Sissy"
2010 Weim Mobo the dog "Fast Spaz"
conmoto
Northern Illinois
Posted: 04/25/12 11:31pm Link  |  Print  |  Notify Moderator
My 06 Chevy DRW w/Duramax LBZ With full tank and me but no aux tank...7640lbs.
Softballdad
Chesapeake, Va
Posted: 04/25/12 09:19pm Link  |  Print  |  Notify Moderator
My 2008 F 350 is 9060 lbs full of fuel.
JOB 1 '08 F-350 4X4 LARIAT CC 6.4 DRW 4.10
B&W COMPANION 5TH WHEEL HITCH
EDGE INSIGHT GAUGE CLUSTER
FORD MOBILE EASE HANDS FREE SYSTEM
08 HEARTLAND BIGHORN 3670RL
blt2ski
Kirkland, Wa
Posted: 04/25/12 09:33pm Link  |  Print  |  Notify Moderator
Some of you need to go on a diet! My dually crew cab 05 dmax is all of 7300 lbs empty sitting there! Altho with a pipe rack it does gain some lbs, some junque/tools in the back seat put it around 8000-8300 or so.....Then again, I have had 2-3 pallets of concrete pavers in the bed, that put me close to 15-16K IIRC going across a DOT scale......
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
SoCalDesertRider
SanDiego, CA, USA
Posted: 04/29/12 06:29pm Link  |  Print  |  Notify Moderator
My '97 F350DRW diesel 4wd reg cab cab/chassis with 11' steel flat bed weighs 7200-7400 lbs, depending on how much fuel is in the dual tanks, 20 gal each.
05E350 6.0PSD
98Ranger
69Bronco ATC250R CR500
20' BigTex flatbed carhauler
Callen Camper
92F350 CrewCab 4x4 351/C6
HD Springs Bilsteins,
4.56's & LockRite rear
whisperide
Golden Spike area
Posted: 04/27/12 01:51pm Link  |  Print  |  Notify Moderator
Dammit, I can't win this one as long as you're specifying a crew cab. Otherwise, I have the lightest diesel dually.
'06 GMC C2500HD RCLB gasser 4.10:1, 4L80E, custom camshaft
'84 Trans Am 6.2 diesel, 700R-4, custom Class-3 receiver
'69 F350 dually. GM 6.2 diesel, turbo, 700R-4, NP208 all pending.
soling2003
Federal Way, WA
Posted: 04/25/12 11:35pm Link  |  Print  |  Notify Moderator
my 2011 F350 Dually Lb CC with 6.7 with full tank of fuel, all of 38 gal, not 90 like yours, and two small dogs and myslelf comes out right at 9000. My 2010 250 set up the same way was about 8600. Yes, they are heavy! What was kind of weird is that I weighed the each axle then did it again with only one wheel on the scale at a time on one side, it came out that the front was 220lbs lighter on the left side and the rear was 180lbs lighter on the left side. And I sit on the left side....anyone else have this discrepancy or should I try it again.
DW and 2 dogs
2011 Ford F350 Dually LB 4x4 CC 6.7 diesel
2007 Grand Junction 35TMS
Peterson 37(just sold) T-37 R/C Sailboat at home
BobsYourUncle
Surrey, BC Canada
Posted: 04/26/12 12:12am Link  |  Print  |  Notify Moderator
My '07 DRW, with the rack and toolboxes as seem in sig pic tips the scales at just under 10K pounds. That includes ladders on top and in the back, and a hefty compressor in the back.
Rack and boxes with ladders weighs about 2K pounds, so that would put me around 8K pounds without all the stuff in the back
Duramax / Allison
Fire Red
95 Sportsmen 25.5' TT
81 Citation 25' "Tail dragger" "Under construction"
"Workin' man's rig"
Bob's Trucks
Check Out My Rebuild Project
Project Feedback
