RV.Net Open Roads Forum: Tow Vehicles: Helper springs or air bags?
Search only in Tow Vehicles
 > Helper springs or air bags?
manley
Valdosta, GA
Posted: 04/25/12 11:00am Link  |  Print  |  Notify Moderator
I don't want to hijack Patrick45's thread about the Timbrens, so I figured I'd start a new one.
I'd like to improve the ride quality UNDER LOAD on the tow vehicle / TT combo in my signature. I don't squat but about 1" in the rear when properly weight-adjusted, so don't really need the "help."
However, I would like to improve the ride quality when towing. Specifically, I'd like to eliminate the "bounce" that you get from expansion joints on concrete highways and bridges, as well as from just general highway disrepair.
What does the forum knowledge recommend? Are Hellwig helper springs the "gold standard," or is one brand just as good as another? What about Firestone / Ride Right air bags? (I really don't want to spend a lot of money, but if I can easily / quickly / cheaply improve the ride, am willing to spend SOME money.
Thanks in advance.
2010 Chevrolet Silverado Z-71 4X4
6.2L Vortec, 3.42, 6-speed Automatic, Hensley Arrow
2009 Keystone Cougar 29RLS
Dave&Monica
Ontario
Posted: 04/25/12 11:25am Link  |  Print  |  Notify Moderator
Air bags are adjustable to the load...that's their advantage.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
Chuck&Gail
In the Colorado Mountains
Posted: 04/25/12 12:58pm Link  |  Print  |  Notify Moderator
IMHO if you have a tow trailer (not sure from signature), first try adjusting the WDH, weighing everything fully loaded, and being sure tongue weight is correct. Just a few hours getting things set up right may be all you need.
Chuck
Wonderful Wife
Australian Shepherd
2010 Ford Expedition TV
goducks10
Keizer OR
Posted: 04/25/12 11:29am Link  |  Print  |  Notify Moderator
My guess is you have a lot of TT for the truck. At 33' long and around 74-7500lbs loaded your TT is controlling the truck on those bumps. A heavier truck would off set the TT's length and weight. I suppose you could try Timbrens or maybe even some SuperSprings. IMO I think the truck is being asked a lot to controll the up and down movements of the long of a TT.
Cool Canuck
Winnipeg, MB, Canada
Posted: 04/25/12 12:23pm Link  |  Print  |  Notify Moderator
Airbags will "Firm up" the ride. Not sure that's what you are looking for.
04 Everest 343L
2011 F250 PSD CC
SOLD - 01 F250 PSD S/C S/B
SOLD - 00 Jayco 313
tvman44
Southwest Louisiana
Posted: 04/25/12 12:51pm Link  |  Print  |  Notify Moderator
Air bags my first choice.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
APT
SE Michigan
Posted: 04/25/12 01:25pm Link  |  Print  |  Notify Moderator
Springs (and air bags) are designed to hold the load up. Shocks are designed to help with bounce. In my experience, GM's OEM shocks suck when brand new. That is where I would invest ~$300.
2012 VW Passat TDI
silverbullet02
Kingston, TN
Posted: 04/27/12 11:57am Link  |  Print  |  Notify Moderator
^^^This^^^
2007 Dodge 2500 QCLB, 5.9 Cummins---Roadmaster sway bar, Rancho RS9000's, Firestone air bags, Rickson 19.5 wheels, Michelin XDS2 225/70's.
2007 Arctic Fox 811
skipnchar
Topeka or somewhere else
Posted: 04/25/12 01:02pm Link  |  Print  |  Notify Moderator
That's exactly what a properly sized and properly adjusted weight distributing hitch is designed to do. Size your spring bars for 15% of your trailers GVWR and adjust it to transfer the correct weight and it should ride nearly as good towing as empty. If you're bouncing a lot you PROBABLY have either too light spring weights or not transferring enough weight.
My OPINION is that air bags or helper springs really have no place in towing a travel trailer. Just fine for truck campers or 5th wheels though.
Good luck / Skip
manley
Valdosta, GA
Posted: 04/25/12 01:13pm Link  |  Print  |  Notify Moderator
Didn't take long for the "you don't have enough truck to handle that trailer" crowd. I appreciate their input as well.
I honestly believe that the weight distribution is extremely well-adjusted, because as I said, there is only 1" of squat in the rear. I did not say it, but the front is at unloaded height as well. No, I have not "scaled it," and maybe I should to be sure... but again, it is set-up properly.
I don't have overweight problems, and don't have sway problems. I simply wanted a "little" better ability to handle rougher roads.
Thanks again, gentlemen.
