coolbreeze01 wrote: I would put 65# of air in, grease the bearings, check the brakes, the lug nuts and travel. Have a smooth trip.
Don't overinflate the tires, not all tires take 65#, and that's not enough for some. Use the sidewall rating on the tire and/or on the sticker on the trailer.
The Op stated his TT has a sticker that says 65psi for the tires.
SEMPER FI
Joe,Joyce 4 kids & 3 dogs
2004 Ford Excursion LTD 4x4 V-10 3.73 Gears, Hellwig Swaybar, Bilstein Shocks & Steering Stabilizer, Roadmaster Active Suspension, Super Duty Tow Mirrors
Reese Dual Cam & Prodigy Brake Controller
2010 Jayco G2 32BHDS.
Exactly
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis ST Tires.........
The 2011 Springdale 291 - East or West coast - designs are almost identical in size and weight and the stock tires should be ST225/75R15D. Your GAWR for that trailer is 8700#/8800# depending on coastal design. So at full load you will still have a nice total tire reserve load capacity of 1360# at 65 psi. If you have taken good care of those tires there is no reason they should not make the trip to Texas. Keep them aired, check them at every stop for excessive heat and drive 65 MPH or less. Have a safe and fun trip.
