RV.Net Open Roads Forum: Need power steering reservoir 2001 F53 Help
 > Need power steering reservoir 2001 F53 Help
nelson
Clio,Mi USA
Posted: 04/25/12 11:16am Link  |  Print  |  Notify Moderator
I have a leek in my power steering reservoir on my 2002 MH F53 Chassis, I removed it and went to the ford dealer only to be told it is no longer available. Came home and been searching the net for new one, No luck so far. Any hel in locating one would be greatly appreciated.
2002 Damon Challenger 348 Ford V10
Blue Ox Auto Stop and Aventa II Tow Bar
2001 Ford Sport Trac with Remco Driveshaft Disconnect
Corkey05
Washington State
Posted: 04/25/12 11:59am Link  |  Print  |  Notify Moderator
I've had good luck by first obtaining the factory part number, then running it through Google. Lots of aftermarket manufacturers out there and you would probably find the one you're looking for. I've also found connections to replacement part numbers that are backwards compatible.
Sure worth a try.
2008 HR Endeavor PDQ - Blazer 4 Down
FMCA F374292
nelson
Clio,Mi USA
Posted: 04/25/12 12:49pm Link  |  Print  |  Notify Moderator
No such luck, I have Ford part number F81D3531BC with no luck, Might need to try to patch mine but would rather find a new one.
Corkey05
Washington State
Posted: 04/25/12 01:35pm Link  |  Print  |  Notify Moderator
I had my Ford v10 MH serviced at a certified Ford truck repair center. Those guys where amazing as they have knowledge pertaining to situations just like yours. I'm sure there's a replacement pump that would bolt right in, but finding it will maybe take the help of someone who runs this gauntlet every day.
The v10 is pretty common in Ford medium duty trucks, so maybe a truck service center could help.
jassrnj
Bath, PA
Posted: 04/25/12 02:10pm Link  |  Print  |  Notify Moderator
X2 on the Ford truck repair center. I have an F53 and have to keep telling myself ... it's a truck with a MH body.
nelson
Clio,Mi USA
Posted: 04/26/12 04:35am Link  |  Print  |  Notify Moderator
I put in an order on line, Now jus waiting to see if they really have one in stock.
nelson
Clio,Mi USA
Posted: 04/27/12 04:41am Link  |  Print  |  Notify Moderator
Update, No luck ordering from Ford Truck Dealer online. Said part was obsolete.
So I am still looking.
John Wayne
Long Beach, Ca
Posted: 04/27/12 01:30pm Link  |  Print  |  Notify Moderator
Motor home wrecking yard, several have been listed in the past,don't have the info on hand at this time.
John & Carol Life members
01 31'Sea View single slide, F53 V-10
96 Toyota 4-Runner auto 4x4 (Remco, M&G brake system)
Security by Bentley
God Bless
KF6HCH
WILDEBILL308
FORT WORTH , TEXAS
Posted: 04/27/12 02:10pm Link  |  Print  |  Notify Moderator
Well have you asked if a new pump comes with a reservoir? I would ask if there was one that would work as a replacement. I then would look at repairing the old one. What is it made of?
PS I would look in a local junk yard I would think a V10 is a V10. I would take the old one to compare.
Good luck
Bill
2003 BOUNDER 38N
5.9 CUMMINS 300 HP
ALLISON 3000MH TRANSMISHION
TOWING HONDA CIVIC ON ACME TOW DOLLEY
nelson
Clio,Mi USA
Posted: 04/28/12 05:53pm Link  |  Print  |  Notify Moderator
It has a remote reservoir that sets next to the air cleaner and it does not come with the pump. Being it sets next to the air cleaner in the front of the MH it would be one of the first victims in a front end collision and I have not found a junk yard that has one as of yet. Going monday to see if I can get it fixed or have one built.
