RV.Net Open Roads Forum: Class A Motorhomes: Cost to service Allison 3000 tansmission
 > Cost to service Allison 3000 tansmission
CA Traveler
The Western States
Posted: 04/25/12 05:54pm Link  |  Print  |  Notify Moderator
gswcgi wrote:
docj:
I am the original owner and the transmission has Transynd. It was serviced at 5,000 miles as originally recommended by Allison & Monaco. The confusion I have is the conflicting advice about when the next service is due. Two Allison techs at a Monaco rally told me that it was good for 100,000 miles and the info given on this site is that I am overdue. ???????????
The 5K service was for a single filter only. New filters have even done away with this change.
There is a time recommendation that you are over. In 2011 with 55K miles on my 04 HR CC recommended no more than 1 more year. So I was headed for a change.
It's probably best to service the tranny.
2009 Holiday Rambler 42 Scepter with ISL 400 Cummins
2004 Honda CR-V
Bob
lanerd
Newport, OR
Posted: 04/25/12 05:59pm Link  |  Print  |  Notify Moderator
You should go by your Allison Operator's Manual. If you don't have one, you can find it HERE.
Hope this helps
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
ASA Glamis
Rancho Cucamonga, CA
Posted: 04/25/12 06:04pm Link  |  Print  |  Notify Moderator
gswcgi wrote:
docj:
The best thing to do is to have the fluid analyzed.
It may be that the fluid is still serviceable and does not need to be changed. Listen to the Allison techs and not the people on the internet.
On one of the diesel forums is the engineer that wrote the specs for Transynd and his recommendations are to have the fluid tested to see if it requires changing. The time frame done not necessarily apply to Transynd.
2007 Jayco Seneca 35GS
rvrepairnut
bc
Posted: 04/25/12 08:18pm Link  |  Print  |  Notify Moderator
according to allison transmissions 295 transynd is good for 300000 miles
sdbounderdiesel
San Diego
Posted: 04/25/12 10:45pm Link  |  Print  |  Notify Moderator
$350 sounds like a very good price to me. I had mine done about 3 months ago and the Transynd fluid alone was about $40 a gallon (5 gals.). FYI, I had the same question about time and mileage criteria for fluid and filters. Mine is a 2008. Called Allison customer service. Gave them my transmission serial number, and they looked it up. For my rig, 48 month time criteria pretty much drives the process. They also gave me the part number for a filter kit (about $60), that has everything you need in it for changing the two filters.
gswcgi
Wandering
Posted: 04/25/12 06:08pm Link  |  Print  |  Notify Moderator
Where do I go to get the fluid analyzed? I have a manual,thanks
'03 Safari, DP, 36" Nissan 4X4 toad
lanerd
Newport, OR
Posted: 04/26/12 10:48am Link  |  Print  |  Notify Moderator
I'm curious... what does your manual state on this subject. My Allison 3000 requires 36 months for filters and 48 months for fluid....or 100,000 (or maybe 150,000...haven't looked at it for awhile) miles which ever comes first. Of course, I'll probably never see the mileage factor as I've only done 31,000 in five years.
I changed my own last year and the 19 qts (had to buy 5 gal) cost me $32/gal and the two filters were another $38. So, for having someone do the job for you, $350 isn't bad. However, doing your own is not that big of a deal.
Good luck..
Ron
Larry Cohen
Mobile, AL
Posted: 04/26/12 06:20am Link  |  Print  |  Notify Moderator
That's a great price....I just had mine done.....found the Transynd on ebay for $218/5 gal shipped and the shop supplied the filters and labor...paid $350 total that way...
2006 Mountain Aire 43
Short haired wife, long haired daschund and 3 sugar gliders are co-pilots, along with Garmin Nuvi 855
05 Honda Pilot with Air Force One supplemental brake
Blue Ox Aventa II towbar
Whirlpool Residential Fridge !!!
docj
Fulltime--Home is where we park it
Posted: 04/26/12 08:13am Link  |  Print  |  Notify Moderator
This is the lab owned by the former Allison fluids engineer that was mentioned in a previous post. They sell an inexpensive pump for taking samples and the cost of sampling is ~$25 each if bought in a 3-pack.
Testing lab
There are plenty of other places who can the analysis. Whoever you use make sure you buy an analysis which provides the "Total Acid" number for your fluid because this is the key parameter with respect to understanding transmission fluid.
Sandie & Joel
2000 40' Beaver Patriot Thunder Princeton--425 HP/1550 ft-lbs CAT C-12
2009 Chevy Malibu LTZ with ReadyBrute tow bar/braking system
Official WiFiRanger Ambassador WFRAMB303
Follow our adventures on Facebook at Weiss Travels
docj
duplicate post
* This post was edited 04/26/12 08:24am by docj *
