wildwood477
Edwards, NY
Does anyone use a preformance chip on their tow vehicle? I would like to put one on my 2011 Dodge 2500HD /w Cummings Engine. I don't really care about Horse Power, would just like to get some more fuel milage. I have looked at the Bullydog Triple Dog Programmer, but it is hard wired to the truck. Would like something that is just Plug and Play, I had one on my 2007 Dakota and worked just fine.
Ranger Smith
Wherever the rig is parked
In my opinion the manufacturers are doing everything to get the best fuel milage they can while keeping it compliant. I would never add a tuner to my truck as it WILL cause problems. Then it will be "I need to remove my tuner because xxx failed" can the manufacturer find out if I had a tuner on there.
Just my opinion
Where I Am Now
Amateur Radio Operator KK9W ARRL VE FT DX2000
Steve and Joy
1999 Winnebago Ultimate Freedom
2011 RAM 1500 Laramie CC 4x4 Hemi
Yogi . . . The Yorkie
Kage . . . The Poodle
Cookie . . . The Chihuahua
Cooper . . . The Aussiedoodle
C.B.
APPLETON WI USA
Here's a link for ya.
www.thoroughbreddiesel.com/dr-performance/predator-cummins.htm
Son and I put the one for 6.0 power stroke. More power and increased milage.
C.B.
CBVP2004~FORD~F350~CC~LARIAT~SRW~SB~4X4~6.0D~
AUTO~PULLRITE 16K SUPERGLIDE~DEMCO GLIDERIDE~
PRODIGY CONTROLLER~C-BETR MIRRORS~
CB Family Fleet
Butch&Barb 13CedarCreek~Duane&Holli 05CedarCreek~Kris&Katy 06Cherokee~ Brian&Maia 11 Laredo
davisenvy
Franklin, NC
I don't have a Cummins, but I do have a Duramax. I have been using Superchips since 1999 on Ford and GM diesels with no problems. I now have a Superchips Flashpaq ($300) on my Sierra. I like Superchips because they aren't a very aggressive tune. I have tried others and they sound like they are ragging my engine. I get 2-3mpg on the tow/performance setting regardless of what the nay sayers may have to say. I've read the DiabloSport yields pretty high EGT's, so I personally stay away from them.
2007 GMC Sierra Classic 2500HD SLT,4x4,Crew, Duramax
2011 Keystone Sprinter 323bhs
Bionic Man
Colorado
I ran a SMARTY Jr on my last truck for 2 or 3 years. LOVED the additional performance that it gave me, but hand calculated, there was very little if any difference in MPG.
If you are only looking for increased MPG you are likely to be disappointed.
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
fla-gypsy
North Florida
Deleted, never mind.
johnrbd
San Joaquin Valley
Best, cheapest way to get better fuel mileage is to slow down.
That's what I do with my gas guzzling 8.1 big block Chev (2005). I consistently get 9.0 o 9.3 mpg at 58-60 mph. Besides, ST tires are only rated to 65-mph - never a blow out - yet.
ib516
Up here!
From a person who is a big fan of aftermarket tuning, and has been using it in various forms for the past 6 or so years, here are the facts:
1. You risk getting your powertrain warranty voided.
2. You are very unlikely to gain any mpg.
3. You will get more power.
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
jauguston
Bellingham, WA
Performance devices will do just that -- performance as in power increases. You will never live long enough to break even on the cost of the device with fuel savings.
Jim
2005 Coachman Sportscoach Elite 402 40'
350hp Cat C-7 w/MP-8
7500w Onan quiet diesel generator
6-Kyocera 130w solar panels SB3024i MPPT controller
Pressure Pro TPMS
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
captainjohn2008
Ontario
I run a H&S tuner on my 6.4L. It is truly plug and play except for 1 power wire. Can be removed, while keeping the tuned program intact. You could plug it in, install the new tune, remove it and drive untill you want to change it.I have been told you can go back to the original tune and the dealer can't tell it was changed, I've also been told they can tell and void the warranty. Don't know which is true. My truck is'nt covered by warranty any longer so not a problem for me anyhow's. Lots of extra power if you want it, 3 different power levels, I only need to use the first level as I find this is plenty for me. I believe the only way to improve on the gas mileage though is to do the delete's which I'm not sure I'd want to do on such a new vehicle. The H&S handles the deletes, and can remove the speed limiter as well. Mine is an 08, I think if my truck was an '11 I'd personnally wait untill warranty was up to do this. JMHO. Enjoy!
