RV.Net Open Roads Forum: General RVing Issues: Water Hookups Far From Camper
 > Water Hookups Far From Camper
mosseater
Dillsburg, PA
Posted: 04/26/12 12:12am Link  |  Print  |  Notify Moderator
We do state parks only, so no water hookups, only electric. I have four of the green, 6gal cheapo jugs that I've been using for 4 years. The plastic spout is tapered and fits nicely in the FW water fill port of the trailer. With the vent plug removed from the jug, I can dump one in the trailer in about 45 seconds. Takes longer to fill them than dump them.
I know I'll need them at some point on an average weekend, so I fill them at the first opportunity and keep them under the trailer. Nothing worse than hearing that empty tank sound late at night when you're ready for bed. If they're already full, just go out and dump them in. Two minutes and you're done. Very seldom need to fill up twice in a three/four day trip. Some folks don't like to mess with lifting the jugs, and I understand that, they are heavy. I consider it exercise.
Sunset Creek 298 BH
Lantley
Ellicott City, Maryland
Posted: 04/26/12 04:33am Link  |  Print  |  Notify Moderator
Wow I have 4 of the same green jugs. I also carry 150' of hose.
When using jugs a practice the same technique however I don't fill jugs until necessary occasionally we make it a weekend on fresh tank without refilling
07'Duramax dually,12'Open Range 399BHS
Hawkshead TPMS,Hensley BD3,Killerbee exhaust brake
Blue Ox Bedsaver,air bags w/compressor
Arvika pin box bike rack,Bak Flip tonneau cover
5500 Onan LP,EMS-HW-50
14'Porta Bote w/8.0 Nissan
Vu Cube 2000,Splendide 2000S
CincyGus
Cincinnati
Posted: 04/26/12 04:46am Link  |  Print  |  Notify Moderator
I have two 5 gal Aqua-Tainers pictured above. I bought a $9 12v pump and 10' of clear tubing. Added some wire to the pump and a connector that matches my battery maintainer connection that is already wired to the battery and I can plug right in.
Take the jugs to the spigot, fill them in the bed of the truck, drive back to the camper, remove the cap off the tanks, drop in the pump, put the clear hose in the gravity water inlet and plug it in. It pumps about a gallon a minute. It's a little submursable pump like you would use on a small fountain or fish pond. Just small enough to fit down through the opening in the aquatank.
2011 Silverado Crewcab 4x4
2012 Passport 238ML
Hope your travels are safe and the friendships made camping are lasting.
6.7 tow rig
kentucky
Posted: 04/29/12 06:09pm Link  |  Print  |  Notify Moderator
rk911 wrote:
stretch your water supply by using the park's showers and washrooms.
One of the main reasons we bought a camper was to never, ever have to use those. In the 20 years we have had a camped Im happy to say I have not set foot in a bathhouse.
2012 Dodge Ram 2500 Cummins 4x4 3.73 rear end
2013 Primetime Lacrosse 318bhs
searfoss
East Stroudsburg PA USA
Posted: 04/29/12 06:56pm Link  |  Print  |  Notify Moderator
We stay mainly at state parks, I fill up the frsh water tank when I arrive, and carry hose to refill if I run out. DW and DD use the RV shower, DS and I use the camp ground shower. However we found the key to not having to re-fill the tank is that we wash the dishes at the camp ground sinks. Its faster and less messy than trying to do it inside the RV.
Poconos Pennsylvania
2007 Gulf Stream Gulf Breeze 23TRS
2004 Dodge Ram 1500 Quad Cab
4X2 5.7 hemi 3.55 rear
RIP Mike, we miss you so much
4x4Bob
California.
Posted: 04/30/12 12:07am Link  |  Print  |  Notify Moderator
I built a portable pumping station by mounting a 12 volt water pump to a board. Next I wired the pump to a switch box so I can turn the pump on and off. Added two 10 feet clear water lines that are rolled up and stored. To use, I run an extension cord from pump station to the TT battery. Then bring two 5 gallon tanks of water back to the TT and sit them on the ground. Drop in the suction side hose and put the other into the fill spout on the TT. It takes about 3 minuets to empty a tank. Make another trip if I need more water.
This sure beats trying to hold 40 lbs up in the air while the water drains into the TT.
Bob
2001 2500 Silverado LS 4x4 6.0, 4.10
2007 Jayco Eagle 288RLS
Cocktails for 6, Dinner for 4, Sleeps 2
End of dirt road, no signs in sight, sun going down: I am not lost, just getting ready to go camping.
mowermech
Billings, MT
Posted: 04/30/12 07:16am Link  |  Print  |  Notify Moderator
cm11599ps wrote:
concord32 wrote:
OK I'll ask if you are using that much water where is it going. Shurley you will also need to dump then. Fill up on the way. No?
We have a tote to bring the waste to the dump station.
What do you do if the IS NO "dump station"? (That is simply a fact of camping life around here!)
Personally, I learned to conserve water. We can go nearly a week without refilling or dumping.
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
cm11599ps
Long Island
Posted: 04/30/12 10:39am Link  |  Print  |  Notify Moderator
We ended up getting some more hose. Leaving today so hopefully it reaches. Lol
dannytas
Pioneer, CA
Posted: 04/30/12 11:09am Link  |  Print  |  Notify Moderator
We boondock alot and we carry 2-7gal and 2-6gal water cantainers. I've rigged up a an old water pump, with a switch, that hooks up to a 12v plug. The inlet hose, from the pump, into the container, the output hose into the fresh water fill spout. Done.
'12 Keystone Cougar 297RKSWE
'03 Dodge 3500 QC 4X4 Long bed Dually
DW-Lynn
BigDog-Kelley
LittleDog-Kroozer
