RV.Net Open Roads Forum: Class A Motorhomes: Noisey Dash Air Fan
 > Noisey Dash Air Fan
hhornig
Eagle, NE
Posted: 04/25/12 02:26pm Link  |  Print  |  Notify Moderator
My dash air fan is howling like a bearing is going out on my 97 Monaco DP. Does anyone know how to get at the fan? There appears to be a box with hoses coming out on the outside firewall , but it looks pretty tight to get at. Is it possible to get to it from the inside?
past-MIdirector
Michigan
Posted: 04/25/12 02:58pm Link  |  Print  |  Notify Moderator
Spartan and Freightliner chassis with Cummins used Desco systems. They have a manual on the Desco web site. On our 2004 Bounder the fan motor burned out. Access was by pulling the panel off in front of the passenger seat. Fan motor was easy to remove once the panel was out of the way.
wolfe10
Posted: 04/25/12 03:17pm Link  |  Print  |  Notify Moderator
You may also be able to lube the fan bushings. Use a light, non-detergent oil such as sewing machine oil.
Brett Wolfe
1997 Safari Sahara 3540
EX: 1993 Foretravel 36' U-240
crankshop1000
se michigan
Posted: 04/25/12 03:33pm Link  |  Print  |  Notify Moderator
Some fan motors have a hole in the outside of the fan motor (outboard end) covered by a sticker.You might get lucky and have one with the hole.A shot of turbine oil will probably cure the squeal. I have seen other s actually drill a small hole in the motor end center of the shaft to lube the bushing.
CampingJumble
San Diego
Posted: 04/30/12 10:59am Link  |  Print  |  Notify Moderator
I don't really remember how to get to it.. Have you had a professional look at it yet?
