RV.Net Open Roads Forum: Class C Motorhomes: "hot fuel" syndrome, 460 V8
 > "hot fuel" syndrome, 460 V8
mowermech
Billings, MT
Posted: 04/25/12 02:41pm Link  |  Print  |  Notify Moderator
I have been told by several reasonably knowledgeable people that my Tioga suffers from "hot fuel" syndrome when traveling on a hot day. Apparently, the under body temperatures get so high that the return fuel heats the fuel in the tank to the point where the engine vapor locks (for want of a better term, I thought fuel injected vehicles didn't have that problem, but...) and quits. After it sits for 30 minutes to an hour, it starts and runs fine for 100 or 200 miles, no problem. If the fuel tank is at 1/2 or lower, filling it with cold fuel from underground tanks also solves the problem.
I have become doubtful of the reliability of this thing, and hesitate to go anywhere.
Is there a REAL fix for this real or imagined problem, other than filling the fuel tank every hundred miles? Buying fuel every 2 hours gets annoying!
CM1, USN (RET)
Toad: 2006 Jeep Rubicon LJ
the bear II
Torrance CA.
Posted: 04/25/12 03:07pm Link  |  Print  |  Notify Moderator
Travel only on cold days....just kidding.
How about ducting some air from the outside of the MH towards the fuel tank. Like they do with brakes on race cars.
In the past I have taken some heat resistant material and wrapped the fuel lines to keep them from getting too hot.
On one truck I used heater hose and cut it down the length and slipped it over the fuel line and wire tied it in place. Also be sure to put something between the hold down clamps for the fuel line and the frame to isolate the heat.
I just thought of another solution that might work. Place a spray nozzle forward of the fuel tank and spray water on the tank to help keep the temperature down through evaporation. It works to lower the temp on radiators by 20+ degrees. I used a junk windshield washer tank and pump hooked up to three misting nozzles I bought at a hardware store. Hooked up a switch in the cab and would turn on the misting spray as I started up a hill towing a large trailer.
pnichols
Santa Cruz Mountains
Posted: 04/25/12 03:11pm Link  |  Print  |  Notify Moderator
Does a 1995 (or maybe even a 1994 chassis in your 1995 Tioga) Ford 460 even have individual cylinder fuel injectors?
(Sounds a bit too early to have this to me, but I know very little about the Ford 460 V8.)
Phil, 2005 E450 Itasca 324V Spirit
mowermech
Billings, MT
Posted: 04/25/12 03:14pm Link  |  Print  |  Notify Moderator
"I just thought of another solution that might work. Place a spray nozzle forward of the fuel tank and spray water on the tank to help keep the temperature down through evaporation."
Now, THAT I like! I could go one better and wrap the tank in several layers of burlap and wet it down! The evaporation of the water from the burlap would keep the tank cool!
Good thinking, I may try that!
Now, where can I mount that 5 gallon water tank...
mowermech
Billings, MT
Posted: 04/25/12 03:23pm Link  |  Print  |  Notify Moderator
I have never looked to see if it is TBI or port injection.
I don't know...
Checked the Chilton's manual, the '94 and '95 460 (7.5) engines had multi-Port fuel injection.
'93 and earlier were EFI.
gotsmart
Aberdeen, WA
Posted: 04/25/12 03:30pm Link  |  Print  |  Notify Moderator
You can install a fuel cooler on the return fuel line:
linky
Google it. There are simple coolers, ones with electric fans. Some even fab them out of tranny coolers.
2005 Cruise America 28R (Four Winds 28R) on a 2004 Ford E450 SD 6.8L V10 4R100
2009 smart fortwo Passion with Roadmaster "Falcon 2" towbar & tail light kit - pictures
pnichols
Posted: 04/25/12 07:31pm Link  |  Print  |  Notify Moderator
What is nagging in the back of my mind is "why didn't this happen right from the git-go when your Tioga was new" ... if it was hot fuel related?
Seems like SOMETHING has changed over time! I wonder if a new fuel pump wouldn't fix the issue? For improved reliability, I'm a fan of changing fuel pumps after too many miles anyway - just on general principles so you aren't left stranded by the side of the road from a suddenly failing one. A 1994/1995 460 is probably due for a new one.
* This post was edited 04/25/12 11:32pm by pnichols *
Dakzuki
Carnation, Wa, USA
Posted: 04/25/12 07:37pm Link  |  Print  |  Notify Moderator
My 94 E350 460 is port fuel injected. I had an 89 460 F250 that was too.
2011 Itasca Navion 24J
95 Chinook Premier
mowermech
Billings, MT
Posted: 04/25/12 07:38pm Link  |  Print  |  Notify Moderator
I had the fuel pressure tested, it is within acceptable parameters.
Yes, I have thought about getting one of the external fuel pumps that mounts on the frame rail (they came from the factory in some E350/450 rigs).
Maybe the problem DID exist when it was new, I wouldn't know. I have only had it a couple years.
Dakzuki
Carnation, Wa, USA
Posted: 04/25/12 07:40pm Link  |  Print  |  Notify Moderator
Personally I don't buy that story. I am betting your fuel pump is dying....maybe the pressure regulator on the fuel rail. I can't for the life of me see how you could get that much fuel hot enough to promote vapor lock especially at the pressures the fuel rail runs.
