RV.Net Open Roads Forum: 2004 Dodge 2500 with 4884# of gravel in the bed *pics*
Search only in Tow Vehicles
 > 2004 Dodge 2500 with 4884# of gravel in the bed *pics*
Tarantula
Saint John, IN
Posted: 04/26/12 06:18am Link  |  Print  |  Notify Moderator
This is a good example of why I'd not get on here and ask what I needed to pull what. Most people have no idea of what their vehicle is actually capable of. When I was a test driver for Bosch Automotive, we usually ran with 75% overload.
Our Unit: 2011 Lexus ES. Matador red. . Previously '05 Dodge/CTD & '06 Montana 3000RK.
Ron3rd
Upland, CA USA
Posted: 04/26/12 06:58am Link  |  Print  |  Notify Moderator
ib516
Nice photoshop job, can't be true, you can only haul a small pop up with that truck
Just kidding of course, those old Dodges are tough!
2004 Aljo 250LT
Eaz-Lift WD Hitch
Single Friction Sway Control
Prodigy Brake Controller
Honda EU2000
ib516
Up here!
Posted: 04/26/12 09:32am Link  |  Print  |  Notify Moderator
His mpg on the way home hauling 4800# in the bed....
2010 Cougar 322QBS 5er
2007 Dodge 3500 SRW Megacab, 4x4, 5.9L Cummins, 3.73, 48RE auto
HYPERTECH MAX ENERGY or DIABLO PREDATOR tuning
MBRP 4" Turbo back
Scangauge2 for Boost, Coolant temp, Rail press & Trans Temp
Torklift Stable Loads
atvanish
Central PA
Posted: 04/26/12 10:25am Link  |  Print  |  Notify Moderator
I believe the 4800#... I did something similar once (load of solid bricks stacked in the bed) of my '07 5.9l 2500 - about the 5k# as well! although I admit I 'cheated' with timbrens... but drove perfect the back roads I went home on (it wasn't far or highway)...
2007 Chevy Cobalt (Gas Saver!)
2006 Dodge Ram 2500 POWER WAGON, 4x4, Hemi, 4.56's
2005 Dutchman Lite 27B
45Ricochet
North Idaho
Posted: 04/26/12 01:27pm Link  |  Print  |  Notify Moderator
This time of year the 3/4 minus gravel can be heavy because of water content, per yard. I get 1 or 2 loads per year about that size and I can certainly see her squat. Just wonder what his tires are rated for Guessing he was over just a bit . He don't work with you right
06 Ram 3500 CC LB Laramie 4x4 Dually 5.9 Cummins Smarty Jr 48RE Jacobs brake
GVWR 12,200 RAWR 9350
06 Grand Junction 34' High profile 15500 GVWR 3200 pin Mor/ryde 5500 Onan genny Dual A/C Wet bolts
27' Hallett 502, 500HP
ib516
Up here!
Posted: 04/26/12 01:30pm Link  |  Print  |  Notify Moderator
Nope, he's a Paramedic. He lives about 500 miles from me.
blt2ski
Kirkland, Wa
Posted: 04/26/12 09:15pm Link  |  Print  |  Notify Moderator
Looks like a NORMAL day at work, 2 tons in a SW DOT class 2 twuck! 12K was not an uncommon wt to be at with my old SW K3500 CC twuck. 12K is a middle load with my current 3500 duallie. 15K is more on the top end for a load. That is Gross loads out of quarries etc!
Rock as noted, about 2300-2500 lbs per yd, with minus's and sands upwards of 2800-3000 lbs per yd. Topsoil is in the 1500-2200 range depending upon the blend. sawdust/barks will be in the 800-1200 range depending upon how wet etc. 500# sod pallets can be in the 2000-3500 range. Had a few pallets that literally were dripping water out of them. Them loads were HEAVY!
Concrete pallets of pavers, wall block etc are in the 2400-3500 lb range depending upon the brand etc. I've frequently had 2 pallets of the lighter ones in SW 25 series rigs, even did 3 a time or two in my dually. My dumptruck on the other hand, upwards of 7 tons in it is not uncommon. 3 tons is pretty common in the dually, 2 tons in SW rigs. Long WB rigs also seem to handle the load better than shorter ones.
Along with what one will find, MOST of the time 95% of the time, the whole amount will go on the RA, almost none on the fa, even if the load is balanced over the RA, and to a degree to the front of the box too.
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
Check RV.Net Blogs at: blog.rv.net
