Rmcgrath53
Howell
Tryed a search and came up 0. Does any one know what the difference
between the 2 other than price. I am looking at the costco and the trojan t 145.
i cxan get the t i45 for 179.00 plus a 24.00 core charge.it is rated at 260 ah. the costco arerated 224ah for 79.00 weght around 64 pounds a questamite. The trojans are 72lbs
Thanks
2008 keystone Everest 345s re
2002 F350 4x4 7.3 diesel crew cab dually. 135,000 miles extra leafs.
Banks stinger/ with an edge attitude set at tow
prodigy 3p curt 20k hitch
trail air suspension trail air pinbox
2 e2000 honda w parralel kit
560 watts solar
RoyB
King George, VA
The T145 Plus specs from Trojan Web site
6 VOLT battery
weight 72LBS
Will produce 25AMPS for 520 minutes (Thats over 8-1/2 hours)
Will produce 75AMPS for 145 minutes (Thats is almost 2-1/2 hours)
rated at 260AH
10-3/8 LONG
7-1/8 Wide
11-1/2 High
This is one nice battery from its specs...
I did find this on-line for the Energizer GC-2
6 VOLT battery
Will produce 25AMPS for 447 minutes
Will produce 75AMPS for 110 minutes
rated at 225AH
This one sounds alot like the TROJAN T105 model
last
edited 04/25/12 04:49pm by RoyB *
View edit history
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
Snow_King
Gold Canyon, AZ
Costco batteries are made by Johnson Controls.
They are a good battery for the money.
Somewhere in a Fifth Wheel - Where it does not Snow
smkettner
The specs speak for themselves. If Costco lasts half the years you are still money ahead on that.
Either can accidently get boiled dry or accidently left flat dead and sulfate just as easily.
I did and would still choose the Costco brand unless I absolutely needed the extra capacity.
675 watts solar
MrWizard
Traveling
I had some T145's, Trojan T105's have a higher reliability record and were listed on Trojans own web site with a longer warranty
if your really into getting Trojans get the 105's
Connected thru Verizon with HotSopt WiFi using a Samsung Galaxy Nexus
I BOUGHTthis phone
ArcticDodge
Sammamish, WA
If I was going with a substantial off the grid solar setup I'd get Trojans or another equivelant high end 6V. For the average camper, the Costco batteries are a good value.
2009 Komfort 256TS
2001 Dodge Ram 3500 QC 4x4 Cummins DRW
2005 Dodge Durango Limited AWD HEMI
2001 Sebring Convertible
1995 Miata M-Edition
2005 DRZ400
1 Wife 2 Boys UW & Bellevue College
1 Trixie (Bichon Frise)
Only 23 years to retirement!!!!
Photog101
Garden City, Michigan
I had 4-6 volt Costco batteries in a Class "C" that got used on a daily basis. Those batteries lasted 4 years until I sold the unit. My brother had 4 in his Class "A" that he lived in until he went into the hospital for 9 months. He was in Lake Havasu and I was in Michigan. His camper sat in dry storage but had electricity hooked for a battery tender. After his hospital stay, he had to replace all 4, just 6 months after he got back to his coach.
I have heard others that use their camper infrequently, with Costco batteries, don't get as much life out of them as people who use them often. It could be the that the batteries are not worked enough.
I went to Trojans on my subsequent units, because I no longer live out of my units and for the piece of mind after my brother's incident.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
MEXICOWANDERER
las peƱas, michoacan, mexico
MrWizard's answer is right on the money. T-145's have acid starvation problem. Always did and probably always will.
Telephone advice is available at any golf pro shop at any major golf course. They are the CHEAPEST and MOST DEMANDING golf car battery consumers on the face of the earth.
pianotuna
Regina, SK, Canada
Hi,
Going with solar means far less stress on the battery bank--assuming proper sizing--so I'd go with the Costco batteries.
ArcticDodge wrote: If I was going with a substantial off the grid solar setup I'd get Trojans or another equivelant high end 6V. For the average camper, the Costco batteries are a good value.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
KendallP
Grants Pass, OR
mexbungalows wrote: MrWizard's answer is right on the money. T-145's have acid starvation problem. Always did and probably always will.
Yep. No free lunch. Same size volume. Something has to give. If you have money, don't care about longevity and just want to cram the most capacity per the given space... then go with T-145s or what-have-you.
Now Gramps,
I was thinking they might also have less sludge capacity in the bottom too. No?
Or do they do it with thinner plates, or...?
And back to the OP...
I have been unable to find it, but I did a survey a few moons ago on the Costco GC2s. The overwhelming majority of posters reported excellent results, often with 7-10 year on 'em and still going strong.
Wiz was one of those. He's a full timer that cycles to around 50% or so... pretty much every day. I believe he reported many, many cycles out of his.
I have seen no data to show that a T-105 will last twice as long as the Costco/Sam's GC2.
Cheers,
Kendall
1986 Winnebago Chieftain 22RC
Our Camper (with no payments)
