RV.Net Open Roads Forum: checking timing on an 85 P30 454
 > checking timing on an 85 P30 454
stepside454
st. Louis area
Posted: 04/25/12 04:07pm Link  |  Print  |  Notify Moderator
Id like to check the timing on my motorhome. I crawled underneath, I can see & touch the timing tab, but how do I get a timing light on it. I cant see it through the doghouse. It almost looks like one has to remove drivers side wheel & get to it through the wheel well. any ideas ? much appreciated john
ronmc
Brownsville Tx. 78526
Posted: 04/25/12 05:06pm Link  |  Print  |  Notify Moderator
From underneath,fasten timing light to #5 plug wire, other wire to ground. I think it's 5*before top dead center.Its been a long time since I did this so take it for what its worth. I think you have to take off vacuum line too.Do not change timing if its running OK. My advice only!!
Ron
2002 Kountry Star
2007 Honda CRV
Used Brake Buddy
Mike Hohnstein
Germantown, Wi
Posted: 04/26/12 07:57am Link  |  Print  |  Notify Moderator
Make sure the HEI advance weights are moving correctly and not rusted up. My procedure was to advance until I heard it ping on hard accel then back off until it didn't. Never broke a piston and my P-30 always ran well. However it one is hard of hearing this won't work. I ALWAYS carried a complete replacement distributor/coil/wire package with me.
grousehunter 61
pollock idaho
Posted: 04/26/12 09:50pm Link  |  Print  |  Notify Moderator
We never used the motor air conditioner, just the house air. I removed the compressor and everything related to it. Now I just lay on the air cleaner with the motor running and check it. With the compressor and condenser gone the 454 run cool even up hills. Just my way of doing things.....
Rodger & Teri
1985 Sportcoach / crosscountry
1983 Camaro / 1971 Chevy 4x4
chessie's named sonny & choc and a red setter named star
http://sportcoach.blogspot.com/
