RV.Net Open Roads Forum: How to get a 1/0 wire to connect to a PD 9260
 > How to get a 1/0 wire to connect to a PD 9260
mcnurlenj
Harper, Iowa
Posted: 04/25/12 04:55pm Link  |  Print  |  Notify Moderator
I found some wire that is a hair larger than 1/0. I want to replace the wires from the batteries to the converter. I can get the connections for the battery side but don't know how to connect to the converter. Any ideas would be greatly appreciated.
BFL13
Victoria, BC
Posted: 04/25/12 05:18pm Link  |  Print  |  Notify Moderator
One way is to use short lengths of wire that will fit in the converter (or Dc panel lugs) and have ring terminals on those short pieces. With rings on the ends of the 1/0, just bolt the two rings together and wrap with tape.
2003 Chev 2500HD Gas, 2003 Komfort 26FS 5er
See Profile for Equipment List
RoyB
King George, VA
Posted: 04/25/12 05:21pm Link  |  Print  |  Notify Moderator
My PD9260C has double screw down slots for large battery cables. The output terminal maximum rating is for 2AWG size battery cables according to the manual.
PD9260C Converter/Charger
I would use something like this Blue Sea Systems 2106 MaxiBus 250 Ampere Common BusBar (4 x 5/16-Inch Stud Terminals) and use the proper size 1/0 cable ring terminal to fit a 5/16-inch stud. Then you could run a short 2AWG size cable from the bus bar to the PD9260C terminal.
Available Here
* This post was edited 04/25/12 05:43pm by RoyB *
Roy and Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
POPUP PHOTOs-Pg52-Pg56
mcnurlenj
Harper, Iowa
Posted: 04/25/12 06:26pm Link  |  Print  |  Notify Moderator
Cool, thanks for the ideas.
Photog101
Garden City, Michigan
Posted: 04/25/12 06:46pm Link  |  Print  |  Notify Moderator
Solder a copper lug on the end of the cable and then cut/grind the end of the lug to fit into the PD Output terminal.
Just a thought.
Combat Vietnam Veteran Support our troops for serving our great country.
1997 Veri Lite RL1200 on a '02, K3500, CC, DRW, 8.1L, Allison, 4.1 gears, Bridgestone 225/70R19.5 tires.
allnight
Bay Area, California
Posted: 04/25/12 08:25pm Link  |  Print  |  Notify Moderator
Don't depend on soldering to hold it...make it a mechanical connection (pinched) first. You can then solder if you want, but it won't be needed.
Soldered connections break over time with vibrations, and in a high-current situation like this it will start to create heat which will exacerbate the problem.
2004 Four Winds Fun Mover 39C (39' including 14' toy hauler garage)
Cat 3126E 300hp Allison MD3066P
Pics of the FunMover
smkettner
Posted: 04/25/12 08:58pm Link  |  Print  |  Notify Moderator
I think you want a wire reducer
http://www.autotoys.com/x/product.php?productid=12876
675 watts solar
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 04/25/12 10:42pm Link  |  Print  |  Notify Moderator
Me too cheap for any of the above. The wire should be as close as possible to the maximum size that will fir the receptacle on he inverter.
Paste flux and solder, stripped wire ends. Use a flat file to reduce OD perfectly to fit. Use only 60/40 solder as 50/50 and below won't be easy at all to use.
BurbMan
Louisville, KY
Posted: 04/25/12 11:50pm Link  |  Print  |  Notify Moderator
I had a similar issue, I used properly sized battery lugs bolted together ina junction box, as posted here.
Hurricaner
Hurricane Utah
Posted: 04/26/12 08:01am Link  |  Print  |  Notify Moderator
Gees... Just cut some strands off and stick it in there. Your only carrying 60 amps which less than half that size wire will easily pass with no noticeable change for a short length.
Sam
Sam & Kari
Hurricane, Utah
2004 34' Damon Challenger 315
