RV.Net Open Roads Forum: Tow Vehicles: 7.3 Diesel Question
Search only in Tow Vehicles
 > 7.3 Diesel Question
Artemus Gordon
Redding California
Posted: 04/25/12 09:09pm Link  |  Print  |  Notify Moderator
My 7.3 does that from time to time. Not a gear head so what I was told its caused by the sensor my chip is plugged into. New sensor it has not occurred again!
hallock5
Posted: 04/25/12 09:16pm Link  |  Print  |  Notify Moderator
Hummm...yeah, I have tuner, as well. Since opinions have varied, I will just call ahead to parts store to see if I can find someone who can give me a definite answer on whether they can pull codes on the 7.3
2008 Jayco Eagle Superlite 28.5RLS
2002 Ford 4x4 SuperCab 7.3 (Jr International) Diesel
Sad to say, time to sell to a good home.
NorthernLimits
Michigan
Posted: 04/25/12 10:09pm Link  |  Print  |  Notify Moderator
Umm....if it is post 1996 then any parts store that has a OBD-II scanner will be able to pull the codes. There isn't any magic here just because it's a 7.3. I have a fancy Snap On MODIS and a cheaper scan tool that I bought from Advance Auto...the cheap one pulls codes and reads data easier than the fancy MODIS rig. My tuner also pulls codes, but isn't as nice in the data department as the cheap scanner.
sirdrakejr
Las Vegas, Nevada
Posted: 04/25/12 10:50pm Link  |  Print  |  Notify Moderator
Moved from 5th wheels to tow vehicles.
Frank
WyoTraveler
Northwest, Wyoming
Posted: 04/26/12 06:39am Link  |  Print  |  Notify Moderator
My 2000 7.3 had a problem when I fueled, especially. if I got lazy and didn't drain the water out of the fuel filter often enough. Sometimes when full timing it was just difficult finding an area where I could open that valve.
2013 Monaco Monarch motorhome
2012 Jeep Wrangler toad
AC6CV/7 ex-W8RUR since 1954
Dave H M
IL
Posted: 04/26/12 07:06am Link  |  Print  |  Notify Moderator
Sure ORilleys had a scanner that would hook up to my 7.3.
However with the alternator/batt icon illuminated on the dash it showed no codes.
A rebuilt alternator fixed it.
Turbo Diesel Dude
Green Mountain, NC
Posted: 04/26/12 07:37am Link  |  Print  |  Notify Moderator
I have a 2011 HD 2500 6.6 Chevy. Had a Low Quality Exhaust Fluid light along with a Check Engine light. Took to nearest dealer (Asheville Chevrolet) where they wanted $100 to read the codes. Put in a gallon of exhaust fluid, light went out, but the CEL light stayed on. My local dealer (Burnsville Chevrolet) reflashed it for free under warranty as it was emissions related. Needless to say no business to Asheville,NC Chevy. About same for my last 6.7 Cummins. Skyland Automotive (Dodge dealer) charged me $178.00 for a fuel filter after I told them I didn't want them to do as I had one home in my tool box. No business there either. Crooks suck. JMHO
charles weidman
hallock5
Posted: 04/26/12 10:11pm Link  |  Print  |  Notify Moderator
Just an update. Sat overnight, ck'd this a.m., NO LIGHT. I am sure it is tied to the exhaust brake in some fashion. I realize my tuner has a Diagnostic app, if I see it again (which I will), I will scan it before it sits over night. Thanks again all.
LarryJM
NoVa
Posted: 04/27/12 02:53am Link  |  Print  |  Notify Moderator
Yes it might pull some codes, but generally the lower end ones don't see all the codes. E.G. a generic scanner will pull an IDM fault, but won't read that IDM code and isolate it to a specific area. As always the devil is in the details. Last year I developed what I felt was the UVC connector fault and had to invest almost $400 in the AutoEnguity system so I could isolate that code to a specific injector since none of the other scanners except the dealer level ones would get to that level.
Larry
