RV.Net Open Roads Forum: Tow Vehicles: 2001 Ford Excursion
Search only in Tow Vehicles
 > 2001 Ford Excursion
jlktbk
Athens,TN
Posted: 04/25/12 05:58pm Link  |  Print  |  Notify Moderator
Going to look at a 2001 Ford Excursion 4 wheel drive with a v-10.... it has 183,000 on it. What to look for?
K Charles
Connecticut
Posted: 04/25/12 06:08pm Link  |  Print  |  Notify Moderator
It's a Ford, look for rust and an exhaust leak.
eye8Ubutler
Maritime Provinces
Posted: 04/25/12 06:09pm Link  |  Print  |  Notify Moderator
There will be many posts to ya thread!
On this Forum there many posts mentioning....spark plugs becoming unseated....due to inadequate threads in the alloy engine version of the V10s.
Chevrolet Silverado 1500 LTZ 2007 (new shape)
4x4 Crew Cab VORTEC MAX (L76) 6.0L V8 4L70E 4.10 axle
factory NHT Max Trailering Package.
2010 Coachmen Freedom Express 280 RLS
"...a Waldorf Salad?, sorry we are fresh out of Waldorfs!".......BASIL FAWLTY.
Gman22
Burlington, Ontario
Posted: 04/25/12 06:53pm Link  |  Print  |  Notify Moderator
Make sure the V-10 is there or you'll not enjoy towing with it .
* This post was edited 04/26/12 06:25am by Gman22 *
2000 Coleman Bayside
2006 Ford Expedition Ltd. 5.4 L/3.73
dodge guy
Bartlett IL
Posted: 04/25/12 07:30pm Link  |  Print  |  Notify Moderator
Check for loose BJ`s and worn hub bearings. ask about the spark plugs and if they have ever been done or became loose (blown out) of the cylinder head. check the trans fluid. the trans has a tendency to fail early if not maintained. also the caliper slides are known for sticking (pulling during braking). otherwise just normal maintanance and wear and tear items.
Good luck!
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
robwen
NE OH
Posted: 04/25/12 07:31pm Link  |  Print  |  Notify Moderator
Check front end...ball joints, tie rods. Trans fluid. Engine oil/coolant.
I bought mine January '11 with 161k miles and have put plugs/coils, shocks, drag link, trans flush, one belt idler pulley, and brakes on mine. It now has 184k. Engine and trans are strong, no leaks, but my front end is very loose and due for all new ball joints. While I'm there I'll do axle u-joints.
Rob a.k.a 69oiler
'03 Ford Excursion V10 4x4 3.73 XLT
'98 SunnyBrook 30DB
'05 Continental Cargo 16'x8' enclosed 9950 GVW
Former Ford IDI and 7.3 PSD guy, hope to get back into a diesel someday.
fla-gypsy
North Florida
Posted: 04/25/12 07:35pm Link  |  Print  |  Notify Moderator
Look for all the same things you would on any 11 year old vehicle with 180,000 miles on it. If you can get the service records it will be easier.
jyh818
Chino, CA
Posted: 04/26/12 11:39pm Link  |  Print  |  Notify Moderator
Look for the axle code on the door jam sticker.
C1 is 3.73 LS
C3 is 4.30 LS
Can't remember what the other codes were for non LS.
If you're gonna tow, look for 4.30 gears.
2002 Ford Excursion XLT 6.8L V-10 2WD, 4.30 Limited Slip
Rear Hellwig Sway Bar
2009 Skyline Nomad 260
Prodigy Brake Controller
EAZ-Lift WD Hitch
Procrastinator
Southern Illinois
Posted: 04/27/12 06:34am Link  |  Print  |  Notify Moderator
As others have said there are mutiple posts about Excursion towing. Let me give you cliff notes.
V10 motor is a very reliable, powerful, and thirsty engine. Early years have had spark plug blow out problems if a spark plug change is not done right. Transmissions kinda blows compared to newer transmissions.
The Excursion is a great vehicle but had one fatal flaw.
Who Ford targeted it to be the primary driver. They tried to make a truck not ride like a truck and put way to soft of springs on it. After 80,000 -100,000 the springs are toast and will need to be replaced. The Excursion will ride better and tow amazing after a few modifications.
Plenty of info out there how to do it all. I just finished mine and I love it. Tows, rides, pulls great. Its an amazing vehicle.
Let us know if you need any assistance in a p.m. and we can steer you in the right way. Nothing better than seeing another loaded Excursion doing what it should be doing (Pulling a huge camping trailer with a large family inside)
2003 Ford Excursion 7.3 diesel
1984 Avion 34W triple axle no slide
Husband, Wife, Son, Daughter, Olde English Bulldog and a Great Dane
rowekmr
Chicago
Posted: 04/29/12 10:44pm Link  |  Print  |  Notify Moderator
I had bought an Ex that was neglected with 80K miles with an extended warranty and had to get work done on the 4x4 system including cracked vacuum line, actuator, stuck u joint and both front hubs replaced plus the usual maintenance of full tune up, brake pads and rotors (corroded), and most fluids flushed. Once it was refreshed it was a stable, reliable tow vehicle that never let me down.
03 Ford Excursion Ltd 6.0L
00 Acura RL
08 Jayco 31 BHDS G2
96 Regal 258 Commodore
1 Wife 3 kids
