O-k so I got some new wheels for my truck...went from the stock 6-1/2 wide wheel to 8 in width...there shouldn't be no difference in the truck height...my tires are 265/r75 16's.
edited 04/25/12 06:47pm by hitchikerman *
blt2ski wrote: Along with NOW you will be able to use the whole 3000 lbs of tire if you have LR D's, or 3400 if you have E's. As that tire is not rated to the sidewall amount unless mounted to a 7-8" rim width.
Marty
05 Chev CC D/A LS Dooley
3 Single axle utility trailers
hitchikerman wrote: O-k so I got some new wheels for my truck...went from the stock 6-1/2 wide wheel to 8 in width...there shouldn't be no difference in the truck height...my tires are 265/r75 16's.
First I assume you meant LT265/75R16 size tires.
There is a P265/75R16 but that would be a 35 psi tire and have it's load de-rated by dividing by 1.1 and I do not find a European metric 265/75R16C listed in Industry Standards book.
Second I do not find a 6-1/2 rim width as an approved size for a LT265/75R16 size tire, so have to wonder who applied this tire on an un-approved rim width.
Third You also failed to mention the Load range so statements on load capacity or inflation levels are all guesses.
LT265/75R16 size comes in LR-C 50 psi, LR-D 65 psi & LR-E 80 psi
