Lawrence V
Philladelphia, PA
Put new tires on the dinghy resulting in traction problems when making turns on dirt or sandy roads. The wheels flip to the opposite direction. Anyone have any experience with this?
Fishinghat
Western Washington, USA
I've never had the problem with either our Hummer or Mustang.
It would help if you told us the make and model of toad.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
navegator
San Diego CA.
You do not mention if the dingy is a 4 wheel drive, and you have it in 4 whell drive when it slips, or if the tires that you purchased are the same as what came with the vehicle, or you installed real narlly new ones.
If you go like a bat out of hell, and want tracktion, forget it, some tires are made to go on paved roads others are made to go off road, and then you have some that are made to go on both surfacess.
If you are driving on sand and you punch the accelerator to much, the vehicle will slip, the higher the speed of the tire in sand the more it slips.
Hope it helps
navegator
MPond
Thousand Oaks, CA
Lawrence V wrote: Put new tires on the dinghy resulting in traction problems when making turns on dirt or sandy roads. The wheels flip to the opposite direction. Anyone have any experience with this?
Are you referring to when the dinghy is in tow, or driving under it's own power?
What make / model?
2003 Country Coach Intrigue, Cummins ISL 400
Toad: 2006 Jeep Wrangler Unlimited (LJ) toad, with just a few mods...
Other rig: 2005 Chevy Silverado 3500 Duramax Dually / Next Level 38CK Fifth-wheel Toy Hauler w/ quads, sand rail, etc...
othertonka
Stockton, CA
Te only time I have had that problem is if I make a tight turn in one direction and then immediatly make a turn in the opposite direction without striagtening the MH and letting the toad front wheels return to their straight direction.In other words back to back opposite turns will cause this.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Healeyman
Carrollton, TX
It sounds as if your new tires have changed the caster, camber, and toe-in settings that your car is set up with.
The tire to road contact patch has moved outside of the alignment (especially caster) specs. Not an uncommon problem.
Have the front end re-aligned. If they can not align it, they will tell you what you need to do to correct the problem.
Tim
edited 04/26/12 09:21pm by Healeyman *
lryrob9301
Maryland
I've been in the auto repair business for over 30 years and never heard of a new set of properly sized and installed tires changing the alignment of a vehicle !!!
2013 Tiffin Phaeton 40QBH
2011 Scion x/B Toad
paulcardoza
Southeastern Massachusetts
Am I the only one who is totally confused with this thread? Where did the OP disappear to?
Paul & Sandra
New Bedford, MA
2003 Monaco Executive M43 DS2
rchonly
Kingman, Arizona, USA
Let's take a stab at what may explain what happened.
If you have a MH with say an eg: 8' plus or minus rear overhang, your pivot point is your rear axle.
When you make a sharp left turn from a straight position with little forward movement, you put your steering wheel hard left and start to move forward the rear is going to swing to the right a considerable amount requiring the toad to follow that movement thus it's steering will start a right turn before you have pulled it forward enough to straighten it out to follow your left turn. If you are in soft sand etc. it may well have a problem correcting itself.
The opposite effect will happen under those conditions going to the right.
Next question or two to consider is did you change the tire size and possibly the wheel type to a wider stance. If you changed the geometry that could contribute to your problem.
I hope that makes sense as it'd difficult to explain without drawings.
Roger
1991 - 38" American Eagle - 8.3 Cummin's w/Allison 4spd
(Purchased 4-15-10 w/5,600 miles on it)
99 Dodge Durango/SLT 4X4 - Toad
lanerd
Newport, OR
I think the new OP has forgotten all about this post and probably will never be back.
Too little info to make an educated guess.
Ron
Ron & Sandie
'08 Safari Simba SBD35 CAT C7
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Safari Intl, CAT
RETIRED!! How sweet it is....
