2inAlabama
Huntsville, AL
Or is my electric element dying?
Just DH & DW
2oldman
Winchester WA
normal
fla-gypsy
North Florida
Normal on my TT also
Old-Biscuit
Across the USA
Some water heaters have a set of thermostats (normal/high) for each mode of heating...one for propane and one for electric.
Some water heaters have just one set for both modes of heating..propane/electric.
Regardless.......both sets are pre-set for same temp. control (typically 140*F normal & 170*F High cut off).
Water or thermostats don't care which heat mode is used......same effect.
Electric takes longer than propane for initial heat or reheat.....that's the only difference between them.
If water does not get as hot on electric as it does on propane:
Are you waiting long enough for water to properly heat?
How often do you drain/flush tank.....hard water? Scaling on element can reduce heating ability.
Do you have one set or two sets of thermostats?
Check grounds?
Check that thermostat is tight against tank?
2007 RAM 3500 QC LB SRW 5.9L CTD 48re 4:10 4K in bed 'quiet genny'
Hit the Road Free & Clear April '07
dougrainer
Carrolton, Texas
2inAlabama wrote: Or is my electric element dying?
They either work or they don't. There is no middle ground. Doug
pianotuna
Regina, SK, Canada
Hi,
Recovery time on a ten gallon electric is 90 minutes. I find that starting with water that is "ground temperature" it takes closer to two hours.
Regards, Don
Kustom Koach Class C 28'5" 256 watts Unisolar, 875 amp hours in two battery banks 12 volt batteries, 2500 MSW watt inverter.
Jim@HiTek
Gresham, OR, USA
Normal.
Work around: 10 minutes before needing sustained hot water, switch on the propane. Shut it off after. No reason for the propane running all the time, IMO.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Fleetwood Bounder, '94
Cummins Diesel, 190HP, 36.5' with 50HP LP boost.
Black Rock Lava Park, Nevada
LVTOCMP
Green Bay,Wis. , Brown
2 you are right. The temperature sensor on electric is a fixed temperature sensor of 125 degrees. The fixed temperature sensor on propane is 140 degrees. I changed my electric sensor to 140 degrees.
Jerry
2inAlabama
Huntsville, AL
We left the water heater on electric when we left this morning at about 10. We came back this afternoon at 6, but the water was only mildly hot. You could easily hold the your hands in it without being burned or even uncomfortable.
Golden_HVAC
Fulltime, CA, USA
2inAlabama wrote: We left the water heater on electric when we left this morning at about 10. We came back this afternoon at 6, but the water was only mildly hot. You could easily hold the your hands in it without being burned or even uncomfortable.
This sounds like a loose connection, a bad heating element, or something else broken. Or the wire to the electric heating element is unplugged now.
Fred.
