danhercules
Norco, ca
I searched and can't find anything. Is there a trick to priming it?
I cleaned the float bowl and jet new can't get it primed. Grrrrr. Runs when i squirt fuel in the intake.
Any tips?
1999 Bounder 36' -Workhorse 454
26' Interstate enclosed trailer
2001 Sand Cars Unlimited 5 seat sandrail- Northstar V-8
1995 21' TPR tunnel hull Deck boat-528 cu Ford. 736 HP on pump gas
2oldman
Winchester WA
Assuming no other fuel system blockages, about 15 pulls on the cord should do it.
old guy
Oregon (pronounced Or e gun)
a friend of mine would shake the gen for a few times and his would start right up. He had troubles with his so he took it apart and cleaned and cleaned. to This day in hunting camp, he shakes and it starts.
ktmrfs
Portland, Oregon
AFAIK there is no priming bulb for the honda. If your having trouble starting and getting it to run, based on your symptoms I suspect either the fuel is turned off, or the pilot jet is completely plugged so it won't start.
2011 Keystone Outback 295RE
2004.5 Silverado 4x4 CC/SB Duramax/Allison
Jerrybo66
AZ
Three or four pulls should start a good working Honda. I guess you have opened the screw to drain/flush the bowl. That should prime it. A Honda ATV mechanic once told me that if I thought I'd cleaned a Jap carburetor, clean it again and once again. He was right. It doesn't take much to mess up these small orifices. That's why I use a small amount of Chevron Pro-Guard in all my small motors.. IMO..
Support the Country you live in or live in the Country you support
2003 Sierra SP 26'Toy Hauler
1997 F-350, PSD, 4X4, red Crew Cab, long bed.
2007 Arctic Cat Prowler, Arctic Cat 500
danhercules
Norco, ca
I was just hoping I was missing something easy. Ill take it apart again. I bet the float is stuck. Dang.
SWD
Land of Living Skies
Had a honda 20 hp engine that had an electronic fuel solenoid. When it went then it was like there was no fuel. Check the dealer.
robert@honda
Atlanta
The EU2000i has a small vacuum-powered fuel pump, since a portion of the fuel tank sits below the carburetor.
Since you've had the fuel system apart, the "prime" needs to be established again. While this can usually be done with a number of pulls on the recoil, the problem may be a air leak or other part of the carburetor that's not put together perfectly, and I do mean perfectly. One gasket, pin or screw out of place and the generator simply won't start.
Make sure the fuel tank is filled all the way with fresh fuel. Make sure the fuel valve / on/off switch is all the way ON. Pull the recoil 10+ times and loosen the drain screw on the float bowl to confirm fuel is getting to the carburetor.
-Robert@Honda
Caveat: I work for Honda, but the preceding was my opinion alone.
2oldman
Winchester WA
robert@honda wrote: Make sure the fuel valve / on/off switch is all the way ON. Where is that located?
robert@honda
Atlanta
2oldman wrote: robert@honda wrote: Make sure the fuel valve / on/off switch is all the way ON. Where is that located?
-Robert@Honda
