RV.Net Open Roads Forum: Travel Trailers: WHERE IS MY WATERFILTER???
 > WHERE IS MY WATERFILTER???
MedTech59
south Carolina
Posted: 04/25/12 08:48pm Link  |  Print  |  Notify Moderator
Hello All:
I own a Cherokee 28RLS 2010. It came with a water filter wrench, a new filter and I have had it for nearly six months and have NOT found the dog gone thing!
Where is the water filter in this thing? Can anyone help me?
Thanks
Vince
MudChucker
Niverville Manitoba
Posted: 04/25/12 08:52pm Link  |  Print  |  Notify Moderator
Maybe you don't have one and the dealer is playing games with you, it should by right near the pump...
2005 PILGRIM 274RL 5SS
2007 GMC Sierra 2500HD SLT 6.0
katysdad
Virginia
Posted: 04/25/12 09:50pm Link  |  Print  |  Notify Moderator
listen and find the water pump. may be in a compartment you have to take a panel off off to get to it such as under sink in bath or have seen some in bottom of entertainment center.
Dodge Ram 3500 DRW Diesel
Earl E
Green Valley, AZ
Posted: 04/25/12 10:22pm Link  |  Print  |  Notify Moderator
You say 2010 and have had it for six months. That must mean used. The previous owner probably had the type I have and sits outside by the cg tap. He took it the filter system with him and forget the wrench and extra filter.
2007 Northwoods Arctic Fox 32 5S Fifth Wheel-for sale now that we are not full-timing
2011 Keystone 23rks Hideout to poke around the smaller parks in the great Southwest
2007 Chevy Silverado 2500 HD Diesel
Prodigy brake control
Dave&Monica
Ontario
Posted: 04/25/12 10:38pm Link  |  Print  |  Notify Moderator
I you have one, it has to be near the pump and the city water connection as both flow through the filter.
Dave
2010 Rockwood 8280WS
2008 F250 CC Lariat SB 6.8L V10
SAR Tracker
SoCal
Posted: 04/25/12 10:39pm Link  |  Print  |  Notify Moderator
My 08 Weakend Warrior (pun intended) came with a wrench, the housing to fit, and (I thought) an extra filter.... how considerate. I use the trailer for about a year, and think "time to change the filter". Imagine my disillusionment when I remove the housing, only to find it empty - no filter element inside!
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
dodge guy
Bartlett IL
Posted: 04/26/12 05:07am Link  |  Print  |  Notify Moderator
On both of my Cherokee`s it was under the bathroom sink. remove the lower front panel of the sink cabinet it will be in there with the pump. and yes a water filter was standard on Cherokee`s.
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
skipnchar
Topeka or somewhere else
Posted: 04/26/12 08:13am Link  |  Print  |  Notify Moderator
It appears you have a "whole house system" and their intent is to filter all water from both the city water connection and the FW tank. They are almost always located close to the water pump as that is the point where both systems are available for connection. My filter sits almost against my water pump and only about a foot from the point where the city water connection is located.
Merrykalia
Appalachian (apple at chun) Mountains in SW VA
Posted: 04/26/12 08:24am Link  |  Print  |  Notify Moderator
We have a Rockwood 8317SS (bunkhouse) and our whole-house filter is located under our pantry, which is adjacent to the dinette beside the bunkroom. You must unscrew the screws on the hinges to access it.
MedTech59
south Carolina
Posted: 04/27/12 07:03am Link  |  Print  |  Notify Moderator
Thank you to all who have responded. I will take your advice and check the items that were suggested. I appreciate you all taking the time to respond.
Regards,
Vince
