RV.Net Open Roads Forum: Travel Trailers: WHERE IS MY WATERFILTER???
 > WHERE IS MY WATERFILTER???
coolbreeze01
Redding, Ca
Posted: 04/27/12 07:12am Link  |  Print  |  Notify Moderator
Mine is under the kitchen sink, along with the wrench. I dump it in the fall, but leave the filter out. Never have used the filter.........
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
dodge guy
Bartlett IL
Posted: 04/27/12 11:30am Link  |  Print  |  Notify Moderator
BTW. you can`t just use a filter from Home Depot or Menards or any home place. they don`t have the flow rate required for an RV system. I tried it once and the pump couldn`t push past the filter. I tried a different filter and the same thing. I ended up getting an RV specific filter and it then worked perfectly! If you want to use water out of your freshwater tank then you really should use one.
Just a little FYI
Wife Kim
Son Brandon 11yrs
Daughter Marissa 10yrs
Dog Shadow
07 Cherokee 32B
02 Excursion 4X4 V-10 4.30 gear 5Star tuner Y-pipe mod Hellwig sway bar
Reese HP dualcam Prodigy brake controller
A bad day of camping is
