RV.Net Open Roads Forum: Class A Motorhomes: Gray tank sensors
 > Gray tank sensors
ClassAGeek
NYS
Posted: 04/26/12 07:23pm Link  |  Print  |  Notify Moderator
I use SeeLeveL sensors mounted on the outside of our grey, black and fresh water tanks. A little pricey but 100% accurate 100% of the time. It is great to never give tank monitoring another thought - ever. After spending spending nearly 6 figures on a MH, what's another $200 to get something that actually works.
http://www.rvgauge.com/products/model_709PH.shtml
SeeLeveL uses your existing wires and takes about 3 hours for a DIY install.
Happy Ford F-53 Class A Owner (2008 Gulf Stream)
2010 Ford Fusion Toad (with 6 speed manual transmission - the only way to tow)
Brake Buddy Vantage, Blue Ox Aladdin Tow Bar,
TST RV 507 TPMS, Power Master Voltage Controller
Dutch_12078
Great Sacandaga Lake, NY
Posted: 04/26/12 08:12pm Link  |  Print  |  Notify Moderator
X2 on the SeeLevel sensors and monitor. Money well spent for my piece of mind. Since the display reads out in percentages (except for the battery level), it's much more accurate than the "Empty, 1/3, 2/3. Full" panels.
Dutch
1995 Coachmen Catalina 322QBXL
F53 chassis, 460 V8, TST TPMS
Quadra Bigfoot EZE Levelers
MrMudstud
Lafayette, LA
Posted: 04/26/12 10:08pm Link  |  Print  |  Notify Moderator
It doesn't hurt to travel with 1/3 to 2/3 full, black and grey tanks. The road action will clean off any debris along the sides of the tanks. I do it occasionally and so far I have no problems. In fact, I deliberately do it annually to make sure nothing does build up. This is my 2nd coach, and it worked on both of them. 2 years ago, I traveled across country in 3 days with full tanks to be sure the process works. Good Luck........
"No One Cares What You Know, Until They Know That You Care!"......."God Bless America"
2003 Pace Arrow 34W, F-53 V-10 22,000#, Avg 8.2 MPG
ScanGauge II, Voltage Booster, Progressive Industries EMS
Water Softener, Safe-T-Plus, Rear Trac Bar, 4 Koni FSD's
donkim
Northcoast, Ohio
Posted: 04/27/12 07:36am Link  |  Print  |  Notify Moderator
Our new to us 06 coach had the 1/3 level lit all of the time on the black tank. I assumed it was crud on the sensors since i didn't know the history of how well the tanks were maintained. I disconnected the wires to the sensor terminals on the black tank and the light was still lit! Long story short, the readout board was bad and there's nothing wrong with the sensors. Not the majority of the failures but thought I'd share it.
Effy
MD
Posted: 04/27/12 07:41am Link  |  Print  |  Notify Moderator
A while ago someone mentioned putting a bag of ice in the toilet/black tank to help scrub the tank before taking off for home. Obviously can't be done for the grey unless you took one of the drain screens out in the sinks and dumped it in there. I have been considering a tank wash for both black and grey. Fairly cheap and easy to install and works off the power of the hose. Any thoughts on these? I will say however that I don't ever really have any issues with my tanks. Plenty of water and dump only when full is a process that seems to work. I back flush them once or twice a year with a kit. Cumbersome and the installed tank wash seems to be the same principal but easier.
2012 Thor ACE 29.1
krev
Victoria, BC, Canada
Posted: 04/28/12 09:10am Link  |  Print  |  Notify Moderator
RayChez wrote:
gbopp wrote:
krev wrote:
Ignore the sensors, they rarely work properly. Try some baking soda down the drain if it's really bugging you. Basically when the water starts coming up the shower drain it's time to empty the tank!
x2
This is the worst advice I have ever read. The reason is when the gray tank water starts to come up the shower it stinks terrible. Best thing is to solve the problem the right way. Many people are just too tight to use the proper chemicals that will keep the gray and black tanks clean. We use enzyme type solution. An organic substance that is produced in plant and animal cells and causes changes in other substances by catalytic action. We use Happy Camper. It is a bit expensive, but it keeps the sensors clean all the time and when you dump does not smell at all to where sometimes people that do not use anything run the neighbors out of the campground.
Calm down RayChez, this was partly a joke as most everyone's tank sensors don't work properly. I do use chemical in the grey. I do look at the sensors but don't get bent if the black says full when I know it's not. With use you get to know your tanks. I have NEVER had my grey come up the shower in our new TT, the old one on occasion but no big deal
1 husband 2 grown kids
2010 F-350 Lariat King Ranch, CC, diesel, short box
2009 Arctic Fox 27T
Janss
Sedona, AZ
Posted: 05/01/12 04:52pm Link  |  Print  |  Notify Moderator
Thanks everyone for your thoughts. I have been sitting awhile, so we'll see what happens after I drive tomorrow. I'll leave some water in the tank to swish around. Don't happen to have baking soda around. Is it okay to put the same chemical I use for the black tank into the gray tank?
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
Five2o
home
Posted: 05/01/12 05:25pm Link  |  Print  |  Notify Moderator
After draining the grey tank fill it 2/3rds with clean water and add a gallon of vinegar. Drive to your destination and dump after 4 or 5 hours.
Add a gallon of vinegar ever few weeks or so before driving to keep em working. Vinegar is cheap at WalMart (ask me how I know lol)
RayChez
Barstow, Ca. USA
Posted: 05/01/12 07:13pm Link  |  Print  |  Notify Moderator
Not sure what kind of chemical you use on the black tank. There are some blue stuff that are just for cutting the smell down. What you need is an enzyme type chemical. They sell them at Wal Mart. Drop a couple of tablets into both black and gray tanks and let it set until you are ready to dump again. It will clean out your inside of the tank and sensors.
2002 Gulf Stream Scenic Cruiser
330 HP Caterpillar
3000 Allison Transmission
Neway Freightliner chassis
2013 Honda CR-V EX
Aventa II
FMCA member
 > Gray tank sensors
